-   JVC GY-HM 800 / 700 / 600 Series Camera Systems (https://www.dvinfo.net/forum/jvc-gy-hm-800-700-600-series-camera-systems/)
-   -   HM700 Won't record (https://www.dvinfo.net/forum/jvc-gy-hm-800-700-600-series-camera-systems/477175-hm700-wont-record.html)
Adam Grunseth April 19th, 2010 04:08 PM
HM700 Won't record
I purchased an HM700 from B&H, and a couple of 32 gig class 6 patriot memory cards from Newegg that seemed to be getting good reviews. I shot a couple of 30 second test clips that worked fine. However, once I shoot more than about three minutes, the camera stops recording on its own. I can not play back the recorded video. If I take the card out and put it in again, it says it needs to be repaired. When I try to repair the media though it gives me an error message.
Is this a problem with the memory? If so what memory cards should I be using?
Eric Deyerler April 19th, 2010 06:27 PM
I had some problems with Verbatim and sometimes errors with 16 GB Transcend, no problems with 8 GB Transcend, Samsung SDHC, Panasonic 10x (Gold-Series), XtreMemory.
Calvin Bellows April 19th, 2010 07:18 PM
I've bought some Core Micro 32 GB class 6 cards from Future Shop and my camera wouldn't recognize them. I've never had a problem with Transcend so I am sticking with them even though they are a bit more $$$
Scott Berrington April 23rd, 2010 05:50 AM
I had the same problem with a 16GB Dane-Elec(Duracell) card. After recording various B-roll shots, we started an interview and within a few minutes the camera stopped recording. After a few more attempts, power down and up, I changed cards(Panasonic Gold) and did not have anymore issues. I returned the Duracell card to Future Shop and exchanged it for a 16GB Panasonic Gold card...no issues since.
Adam Grunseth April 25th, 2010 05:53 PM
Thanks for your reply Scott. I am glad to hear that someone else has had the same problem. I was a little concerned that the problem would turn out to be something to do with the camera and not the cards, so it is very reassuring to hear that you had the same thing and the problem was resolved by switching cards.
New cards are on the way. I ordered two SanDisk Extreme III class 6 cards. JVC says they tested SanDisk cards with good results, and I can't find any examples of anyone saying they have had problems with them, so hopefully they will work for me.
Scott Berrington April 25th, 2010 07:11 PM
In the owner's manual, JVC recommends Panasonic, Sandisk or Toshiba cards. The Sandisk Extreme III cards are now class 10 as far as I know and have very good reviews. I'm going to stick with the Panasonic cards as they are less expensive and are also class 10. Good luck!
