HM700 + hz-ca13 + color cast issues?
I read elsewhere that when someone was trying to use the HD 250 with the hz-ca13 they had serious color cast issues with a variety of lenses. Even though there is an in camera fix (color balance top and bottom of frame separately) he felt it defeated the purpose of using the hz-ca13.
Is this still the case with the HM700? Or is is purely an issue with the quality and type of lens you use? I'm looking to purchase the HM700 body only plus the hz-ca13 and renting some s16mm lenses. |
This topic heading is a bit overly alarmist, when you have an unreferenced and inaccurate statement about another camera.
There is a large body of information on the hz-ca13 in the GY-HD forum. The moderator here and there, Tim Dashwood, has extensive experience with it. My quick impression is that it is pricey, and only as good as the glass you put in front, but that the result is seamless, compact, and very practical. Especially compared to the troublesome setup, bulky, and unreliable nature of most 35mm DOG adapters. The DOF limiting is not as strong, but significant. The HD200 series & the HM700 have a menu operation common to many "broadcast" cameras that adjusts "white shade" chromatic inconsistency top to bottom. This is a feature very useful for any video camera that has interchangeable optics. It's a relatively easy adjustment that tunes the camera to that particular optics. 16mm optics will vary tremendously in their quality - but also character. The most useful scenario is probably renting good modern lenses for DOF limiting, along with possibly improved color and sharpness performance. There may also be some "interesting" lenses valuable for unusual perspectives and looks. I'd imagine in both cases that post processing of the image would be on the cards. I'm not so convinced that planning to use the camera ONLY in in this configuration is a good choice. Many if not most shooting challenges may be best approached with a dedicated lens designed for the camera. Servo zoom and iris control, ergonomics, and dedicated design for video chips and working resolution are all significant factors. If the B&H page is correct, there is only a $500 savings without the 17x (which sells there for $3000). That's hard to justify. Personally, if budget was there, for wide angle, I'd definitely want to be rocking the 13x, and only consider primes when DOF was a specific objective. If more budget was there, I'd be moving up the food chain! |
That seemed like a long winded way of saying it's about the glass. I'm familiar with the HD series, just wanted to know how the new HM700 handles this. If the price difference is only 500, then yes I would get it with the 17x, plus the ca13. I'm particularly interested in the Optar Illumina series if they ever start back into production. I was hoping using a set of matched primes would make the situation easier to handle. I'm fully aware using different glass from different mfg will create different issues for each lens.
The HM700 has matching top/bottom sensors for setting the white shading. If you watch my "Inside the HM700" (I forget which part...probably #2) I demonstrate how easy it is to set white shading now. The HM700 can hold 8 scene and 8 picture profiles on each SDHC card so there is more than enough to fine tune each prime lens and simply load the profile as you swap primes. |
Not sure if you've seen this review by our faithful moderator: http://www.dvinfo.net/prohd/hz-ca13u-review1.php (caution - might be considered "long winded") and I'm just teasing you here Joe - please don't take offense! |
Tim has provided the answer I'm looking for. The HM700 has features that make it easier to handle this. Making a scene file for each lens isn't a problem if the camera makes it easy to do. |
