Downloadable HM700 35Mbps clips for testing in your NLE
I've received loads of emails requesting source sample clips so I figured I might as well just shoot a bunch of clips in different formats and let everyone download them.
For Mac Users: If you have Final Cut Pro 6 installed then you probably won't require anything to watch the .MOV clips. However to import and rewrap the MP4 clips you may need to download Sony's XDZP1 XDCAM EX Clip Browser. You can also import MP4 with FCP's "Log & Transfer." If you DO NOT have Final Cut Pro 6 then you can download the free Open Source XDCAM Quicktime component and drag it into your Macintosh HD/Library/Quicktime folder. This will allow you to work with the quicktimes in Premiere Pro, Media 100 and possibly iMovie 09. For Windows Users: The MP4 import process will be the same as with Sony's EX1 or EX3. Please see your NLE's documentation for the process. You can also download Sony's XDZP1 XDCAM EX Clip Browser for Windows. If you would like to view or edit with the Quicktime MOV files then you will need the XDCAM component for Quicktime for Windows. Unfortunately I can't find a free one, but I can vouch for Calibrated{Q}'s XD Decode component. NOTE: Please don't use these clips to evaluate the picture quality of the HM700. I don't have access yet to either the Canon 14x or Fujinon 17x bundle lens so I shot these with the Fujinon 13x3.5mm. Also, I was playing with the image processing and had the detail turned down to -7, the knee set to 70% (the new lower level), the toe point and stretch were adjusted, cine vivid matrix, cine gamma on -1, ND2 filter employed, 5600K preset white balance. The footage was all shot at magic hour so there wasn't a lot of ambient fill in the shadow areas and the sunlight was very orange. I also wasn't pulling focus to infinity when zooming out to the wide shots. I was really just trying to evaluate the compression quality of the encoder with "complicated" imagery with trees. So have fun watching my mutt take his first dip of the season in slow-motion and go after some very un-afraid Canadian Geese. Variable Frame Rate Quicktime MOV: DASH0080_01_720p60overcrank-MOV.zip (appx. 40.5MB) DASH0083_01_720p10undercrank-MOV.zip (appx. 25.3MB) DASH0093_01_720p60overcrank-MOV.zip (appx. 98.5MB) DASH0094_01_720p60overcrank-MOV.zip (appx. 50.5MB) Quicktime MOV: DASH0095_01_720p24-MOV.zip (appx. 47.7MB) DASH0096_01_720p60-MOV.zip (appx. 56.8MB) DASH0098_01_720p50-MOV.zip (appx. 54.5MB) DASH0101_01_1080p24-MOV.zip (appx. 79.1MB) DASH0102_01_1080i60-MOV.zip (appx. 72.4MB) XDCAM EX MP4 Format (includes full folder structure): DASH0105_01_1080p24-MP4.zip (appx. 81.0MB) DASH0107_01-1080i60-MP4.zip (appx. 76.7MB) DASH0108_01_720p60-MP4.zip (appx. 65.9MB) DASH0110_01_720p24-MP4.zip (appx. 87.0MB) DASH0111_01_720p25-MP4.zip (appx. 121.3MB) DASH0112_01_720p50-MP4.zip (appx. 142.8MB) |
hm700 footage
thanks for posting tim,
i was able to download and play the .mov on mac laptop in qt with final cut pro 6.02 and on pc with adobe cs3 with matrox axio le preset using calibrated softwares codec.. but the .mp4 files come up with error "the movie contains some invalid data."when trying to play in qt. On the pc it just crashes premier/axio le. I wonder if it has something to do with zipping the extra files with the .mp4? ..but maybe I am alone on this though. Some of the footage I have seen appears noisy to me though, I refer to yours sons jacket and beany on the 720p60p footage, before he falls over...aaaaah maybe I am just seeing things. |
Thanks for the footage, Tim.
I got the mp4's to open in the vlc player, seemed to work fine for me. |
For the eight people in the world that don't already know this, VLC Media
Player may be downloaded for free from VLC media player - Overview |
Awesome, thanks so much Tim! The clips play great in Final Cut Pro!
Thanks Tim. I've got 5 NASA Engineering Directorate video guys looking at your footage if you don't mind. They've been using tape-based DVCProHD cameras in that particular division and I work with the Engineering and Science Contract Group. They're really looking at going tapeless but have concerns. Not so much the camera but the overall process. We'll see.
If they like what they see, then we will put in a proposal for a least 2 HM 700's or more. I know that I'm impressed with the clarity and that filmic look. I've also mentioned to them that the Canon 14.4x lense should be even sharper. Interestingly, Avid on MAC using the Perian decoder works pretty good with the QT clips although we think it is doing a transcode to DNXHD 145TR on import. Our main concern was if somebody mistakenly shoots QT vs. MP4 we won't be completely hosed at all with Avid. Thanks again for taking the time. BTW, is that a Canadian Bear swimming in the water??? We don't see too many thick furred animals here in Texas. Just kidding. David |
Clips for testing
Tim, just a question for my understanding. I thought the two models would code the video in MPEG-2 Long GOP files. Am I therefore right, that your files are not the original ones stored on the SD-cards or SxS cards, as your files are in MPEG-4?
Joachim |
Thanks, Tim. I downloaded both of the 1080p24 files (.mov and .mp4). Those trees were certainly a good test of the encoder, plus a chance to scrutinize the "spatial offset" effectiveness with 1080p footage. I appreciate it. It's an impressive camera.
jvchm700 footage.
hey thanks for mentioning the vlc player, forgot about this (although I think there are more than eight people in the world that don't know about this option Chris). Can see them now.
I did naively think that with final cut 6.02 installed I could play in QT, thanks for setting me straight on this Tim. I am still, the only one I guess having trouble ingesting into final cut 6.02 I use cs3/axio le generally and am no power user with final cut. I just opened final cut, set Audio/video settings sequence preference to xdcamex 720p 24 vbr and went ahead and tried to load Tim's DASH0110 01 720P24.mp4. just comes up with file unknown. I must be doing something wrong, in light of everyone else's success. steve lyons |
I'm glad everyone is asking good questions about the post workflow. That's exactly what I hoped for this thread. It is easiest to understand a new workflow if you go through it yourself.
The HM700 & HM100 (and EX1/EX3) do encode the video with Mpeg-2 Long-Gop using the XDCAM EX codec and that's exactly what these mov and mp4 contained files are. I did not re-encode anything. What you get here (after unzipping) are the exact files and folder structures produced by the camera. There is always going to be some confusion over Mpeg-2 being contained in a MP4 wrapper, but I assure you that these are Mpeg-2 and not a MPEG-4 format like AVCHD/H264. These MP4 files are the same as the ones produced by the Sony EX1 or EX3, and the codec used in both cases is XDCAM EX. Quote:
The .MP4 files are another story. They must either be ingested (copied and wrapped in Quicktime) via "Log & Transfer" or wrapped in Quicktime with Sony's software (or JVC's software to be bundled with the camera). This is why the fastest option for FCP users is to shoot in .MOV and just copy the files. You can even directly drop the .MOV files into FCP from the SDHC card and play immediately from the card via USB2.0. Quote:
That's our "Golden Doodle" (Golden Retriever/Standard Poodle cross) taking his first swim of the season, but he's only 1 year old so he still hasn't figured out to keep his paws under the water. He's a hairy Chewbacca-like beast right now. He would normally look like this but he is in desperate need of a haircut. |
thanks Tim, now I understand... then why would you use .mp4 over .mov? |
Edius 5
The .mp4 files work perfectly in Edius 5.
Thx Tim. btw.. the properties in Edius read as follows: (copy/pasted) [Stream type] XDCAM EX Stream [Video info] Profile : Bit rate : VBR 35000000 bps Size : 1280 x 720 [XDCAM EX Clip Information] Title1 : Title2 : Description : Creator : Recording Mode : normal Device : JVC GY-HM700 Status : |
Tim, quick question about the workflow. For FCS2 this would be?:
Step 1: make a folder, copy/ paste from the card into the folder .mov files. Step 2 open FCP6, go to import ->Folder(or File)? Don't think there is a need for Log and Transfer with .mov, right? Also would the best settings be XDCAM EX (720 or 1080) for timeline and render in ProRes HQ? Thanks BTW, I was able to edit these samples with G5 without any problems. |
Yes. The workflow for FCP and .MOV is super simple.
1. Copy files from the SDHC card to the hard drive. (You can skip this step if you're in a real hurry.) 2. Drag and Drop files into FCP bin. (There is no need to use "import" menu or Log & Transfer) 3. Start editing. If you are editing into a new sequence FCP6 will ask you if you want to set the sequence to the same settings as the source clips. I recommend doing this but then go to Sequence settings-->Render Tab and set the render codec to ProRes422. |
I know these tests are not for testing the camera.. but... can you tell us something more now.... ? I bought a HM700 and I am finding some noise. Also the 17x Fujinon lenses seem to have quite a magenta/green fringe. Were you able to test it? I'd love to see some footage done by a professional DOP. Thanks, Marcello
Just tried downloading XDZP1 XDCAM EX Clip Browser from the UK site but you have to register and there appear to be problems on their registration page.
[QUOTE=Dave Tyrer;Just tried downloading XDZP1 XDCAM EX Clip Browser from the UK site but you have to register and there appear to be problems on their registration page.[/QUOTE]
I think you need to compulsorily fill out the details marked in asterisk on the registration page. The phone number entries needs to have - between or it does not go ahead... That's the little problem I faced. Hope that solves... |
Thanks Amir...I did all that but still no joy. I did however manage to find it elswhere. Just got to try and load the .mov files into Vegas now.
I've managed to play the MP4 files in Vegas 9 Pro demo and I'm just trying the MOV files. Is there any difference in using either type ?
Vegas and MOV files
Did you have any luck in playing back the MOV files in Vegas 9? I tried and got the audio track only and the video track did not appear when I dropped the file into the timeline.
Calibrated{Q} XD Decode It's a demo and has grey stipes across it but at least you will be able to play the clip. |
Avid compatibility
Thanks Tim for uploading the clips..
Complete succes with the MP4 files. Took the clips into clip browser and exported them as NLE compatible MXFs I could then import then in the same codec (no transcoding involved). The only hiccuop was the 1080P24 file whcih is actually 1080P23.976 (Avid has both 23.976 and 24) - once i opened the correct type of project Avid could import the clip with no problems. I haven't tried AMA yet as the clips are all of varying speed and raster so it woud have been just one clip per project but i imagine it would work. So far no success with the .movs as I don't have the third party Windows codec. However I have a Mac here with the latest FCP and I'll see if I can import directly to Avid on that. |
Avid (cont)
On the Mac with FCP I can import the .movs directly into Avid.
Frame rate does not seem to matter with the QTs (as opposed to the MP4s) so I could import all the over cranked and undercranked footage straight into a 720P25 project automatically conforming it to that frame rate. Remember Avid ties the format to the project where as FCP is format agnostic. A project in FCP can contain multiple formats, a project in Avid may contain only one. By format I mean raster size and framerate, not codec. In summary you can get all types of files that the JVC GY-HM700/100 generates into Avid. If you are on a PC you will need to shell out about $100 to buy a 3rd party decoder for the Quicktime .mov format, although I suspect eventually QT will support them directly or perhaps with just the MPEG2 component loaded. You will need Sony's free clip browser to re-wrap the .mp4s into mxf format but that is an exceedingly quick and easy process. If you are on a Mac and you have FCP 6.xxx installed you already have a decoder installed and can import the .movs directly into Avid. In summary these cameras have none of the problems of hte previous HDV generations had with Avid. |
when you converted the mp4's for use in Avid, did it retain the original time code upon import?
Sorry Kev - I wasn't subscribed to this thread but yes it did. It will also preserve metadata that is compatible.
Avid updated info
Avid will read the .mp4 files from the BPAV folder directly via AMA (Avid Media Access). Tim's test files did not preserve the folder structure and metadata, so I ran tests directly off the HM700 to confirm. You could work directly off the cards if you were pressed for time, although I would always recommend some form of backup.
UPDATE: the new version of Avid Media Composer (4.02) supports mix and match of framerates and raster sizes within the one timeline. |
First I wanted to say Thanks to Tim for uploading these files. I was just asked today about what new gear I wanted and have been eyeing the HM700 and 100 (depending upon available budget)
I do have a question about work flow. I used the Sony browser to take the mp4 to mxf and got it into Avid MC 3.5 no problem. I will still be distributing in SD on DVD. My usual route is to render the effects then send the timeline to Squeeze via QTREF. When I tried that I got the message that Long GOP cannot go as QTREF. So I guess I will have to choose another option when sending to Squeeze. What is the best option in this case? |
Re: Downloadable HM700 35Mbps clips for testing in your NLE
Thanks for posting that footage. I would love to see some from the new 710 with the Canon lens. That Fujinon is not doing the camera any justice. The chromatic aberration towards the edge of the frame is shockly horrible! It looks like an SD lens on an HD camera.
| All times are GMT -6. The time now is 04:46 AM. |
