HELP! Motion Smooth on HD200/250
Hey,
I JUST rented the HD200 for a feature I am shooting and it seems like there is "motion smooth" like in HD100, however, I cannot turn it off or even find where it is in the menu. It seems like there is a jitter when you shoot people moving. Can someone please let me know where the "motion smooth" is or if its called something different. I am stuck on a feature and I need to fix it ASAP. Any help will be GREATLY appreciated. ! Duke |
Duke,
Turn off DNR on the second page of the CAMERA PROCESS menu. Digital Noise Reduction. Motion Smooth is now gone in the HD200 series, but the new DNR will also increase "the blurring of moving objects." (quoted from page 79 of the HD200 manual.) |
Anything else you can suggest? Duke |
Just make sure your shutter is set for minimum 1/48th or 180degrees. Going to 1/24th or 360degrees will give you too much blur for a film look.
If you are shooting in 60P, then set the shutter to 1/96th or 1/100th to maintain the 180 degree look. Otherwise, I don't know what could possibly be causing it. |
Frame grabs, footage, or some kind of better description of what you're talking about please, your description is vague at best. As comprehensive a description as possible of your current shooting settings would help.
Again thanks to Tim, I can have a great shoot. Duke |
| All times are GMT -6. The time now is 09:55 PM. |
