-   JVC GY-HD Series Camera Systems (https://www.dvinfo.net/forum/jvc-gy-hd-series-camera-systems/)
-   -   2:35.1 aspect Ratio on HD200/250 (https://www.dvinfo.net/forum/jvc-gy-hd-series-camera-systems/93843-2-35-1-aspect-ratio-hd200-250-a.html)
Brian Duke May 11th, 2007 06:28 PM
Hey Tim and others,
Tim mentioned in a post that there was some sort of 2.35.1 aspect ratio setting on the HD200/250. I am trying to get it so we can frame properly on my shoot in the lcd.
Here is a small take of the feature I am working on, unedited of course: http://youtube.com/watch?v=E9L-Kuj_8fQ
Let me know about the aspect ratio feature in the 200/250.
thanks guys
Tim Dashwood May 11th, 2007 06:49 PM
It's in the LCD/VF menu under SAFETY ZONE.
There are two options for 2.35:1.
2.35:1 CE (Centers the frame lines exactly in the middle)
2.35:1 CH (This one shifts the 2.35:1 area into the top of the 16x9 area, and allows you to shoot for a "common top line" incase you need a 16x9 version for broadcast.)
The only problem is that the 2.35:1 frame lines option only exists in 720P24 or 720P25 mode, not 720P60. That's probably why you aren't seeing it.
How is everything going so far?
Brian Duke May 11th, 2007 06:55 PM
Tim,
I actually found it. I got the HD200 today for the remaining of the shoot (Rental) since I am shooting some slowmo. Just setting it up right now.
Its turning out pretty damn good. Thanks to your settings =) I posted a small clip.
Brian Duke May 11th, 2007 06:59 PM
PS>
I posted another question about the bleach bypass and the COMPRESS black level.
Tim Dashwood May 11th, 2007 07:28 PM
By the way, the HD200/250 also now have shutter expressed in degrees like a film camera. This feature only works in 24P or 25P mode as well, but you can find it on the 3rd page of the LCD/VF menu, under SHUTTER DISP. Switch it from SEC to DEG. 180° is NORMAL 1/48th in 24P. 90° is what was used on Saving Private Ryan and the Coliseum scenes in Gladiator.
Jack Walker May 12th, 2007 12:31 AM
Is this equivalent to 1/96th sec.?
What is this supposed to do... add urgency... sharpness... irritability... edge?... or something else?
Stephan Ahonen May 12th, 2007 03:13 AM
Yes, 1/96th, though it's probably actually 1/100th in reality.
It adds... Well, I guess you could say sharpness and edge. You really just have to look at it in context to see how it affects the mood of the piece. It's all in how you use it really.
