-   JVC GY-HD Series Camera Systems (https://www.dvinfo.net/forum/jvc-gy-hd-series-camera-systems/)
-   -   refurbished 100 or new 110 (https://www.dvinfo.net/forum/jvc-gy-hd-series-camera-systems/93399-refurbished-100-new-110-a.html)
Chuck Anschutz May 7th, 2007 07:11 AM
Thanks much for this great site.
I’m contemplating that seemingly well-worn path towards buying refurbished, tight-budget fueled of course. The choice at B&H is $3,895 for a refurbished JVC GY-HD100u or $4,799.95 for a new HD110u.
Most of the improvements from the 100 to the 110 I can do without. But I am concerned with a few focusing complaints with the 100 (maybe the 110’s focus assist and B/W viewfinder significantly improved this?). Also a camera with a foggy history makes me nervous.
If I go with the 100, am I doomed to a lifetime of focusing headaches? Should I sell my blood and get the 110?
Final question: Is the KA551U adapter plate essential for mounting this camera on a tripod?
This camera will do some in-the-field documentary work and also shoot a low-budget film. Maybe it’s obvious, but I’m new to the HD field.
Chuck
Josh Meredith May 7th, 2007 10:02 AM
I got a refurb HD100. For the first week or so, I thought that focusing this camera would always be a pain in the butt, especially having come from a Sony VX2100 with near-perfect auto focus. However, it wasn't long before I had manual focus with the HD100 figured out, and now it isn't an issue anymore.
Jack Walker May 7th, 2007 10:07 AM
The camera has a 1/4" in threaded hole in the bottom like other cameras. Any tripod plate with a 1/4" screw will attach to the camera.
At this point I have a Cartoni Alpha and a Gitzo, and the plates from both heads just attach to the camera.
Jad Meouchy May 7th, 2007 04:08 PM
I don't know that much changed with focus assist in the HD110, but I can tell you that whatever's in the HD100 is pretty easy to get used to. If you have experience with a manual lens, you won't have much trouble 'getting the hang of it'.
The camera does have a standard mount, but if you put a battery kit and dte on the back, the camera is no longer balanced over it. In this case, it may be necessary to build or buy a mount that slides the point back a few inches to maintain neutral balance.
Chuck Anschutz May 7th, 2007 04:50 PM
Thank you much for your replys. Just the information I wanted to hear.
Chuck
Steve Benner May 7th, 2007 08:42 PM
The Focus on the HD100 is great. I would still get the 110 though. The CCD's have better alignment and less chance of SSE (Split-Screen Effect).
Scott Jaco May 8th, 2007 03:50 AM
Where are you getting that info?
The 100 & 110 are pretty much the same camera, except for a couple of bells & whistles. I've read reports on this website from HD110 owners that say they have SSE.
SSE is a calibration issue due to the camera design. How is the HD110 designed differently to avoid this problem?
Steve Benner May 8th, 2007 05:01 AM
From Carl Hicks of JVC,
"Due to improvements in our calibration process, there have been VERY FEW incidents of split screen with the GY-HD110U. In fact, I believe that this is the first incidence of split screen on a GY-HD110 to be posted on this forum, and the camera has been shipping for several months. And, I have not heard or seen ANY incidents of this issue with the GY-HD250 or GY-HD200. With the higher-end electronics of these new models, I doubt that there will be any split screen issues with them."
Chuck Anschutz May 8th, 2007 05:12 AM
I suppose the focus complaints may come from those not used to manual focus.
How much help is the b/w viewfinder in being able to quickly find focus? Also what are the improvements (more settings or something?) in the 110's focus assist?
The camera will be used in some time-crucial docu shooting (i.e. quick interviews and mostly outdoor events) and will be used to shoot a low-budget film, where I'll be able to take the time for proper setup.
I would be interested to know if others believe the CCD setup is different.
Steve Benner May 8th, 2007 05:28 AM
It's not that the CCD's are different, it has to do with the Configuartion of the Alignment of them...JVC, as I posted above, stated the HD110 uses better configuration.
