Playback of HD250 content on HD100
This summer I have a production that will use two different units. One will be a 250 and one will be my own 100. I intend to shoot both cameras in 720 30p. My 100 will be used for the playback deck so I want to confirm that content shot on the 250 will play back on the 100. I know that this "should" work, but if anyone could confirm this then that would help in the planning process. If the material isn't playable I'll need to rent a 100/110 instead of the 250. Thanks for the help.
Ben |
As long as you shoot 720/30 or 720/24 I think you're okay. I don't think 250's 720/60p will play back on a 100/110 but I could be mistaken. I believe that the 250's 720/60p uses a 12 frame GOP while the 250's 720/30 & 24 uses the same 6 frame GOP as the 100/110.
Hopefully someone really in the know will confirm. |
All frame rates from the HD-250 will play back from the HD-100 (50 and 60p included). I know this fact from personal experience.
good times... |
Thanks Stephen.
Ben |
the sales rep in my area said the same thing, yes on both.
I wonder how the HD100 can do that, since it shouldn't be able to read the 12-frame GOP signal.
Sony's new V1 camcorder will even play ProHD tapes via HDMI at 720p60 -- but not 24p tapes. |
| All times are GMT -6. The time now is 09:08 PM. |
