-   JVC GY-HD Series Camera Systems (https://www.dvinfo.net/forum/jvc-gy-hd-series-camera-systems/)
-   -   24P - SD on the JVC110 looks wierd (https://www.dvinfo.net/forum/jvc-gy-hd-series-camera-systems/82385-24p-sd-jvc110-looks-wierd.html)
Peter John Ross December 23rd, 2006 11:47 AM
Can anyone tell me what my shutter speed should be to get a normal, non-smearing look to my standard def 24P mini DV recording?
In HDV, the 24P looks great, but in standard def, it looks terrible and the image smears a lot. I was using 1/48th shutter speed, but it still looks off.
- PJR
Scott Jaco December 23rd, 2006 11:55 AM
HDV 24p mode has a default shutter of 1/48th
Are you sure that your shutter was still at 1/48th when you switched to SD?
On my camera, the default shutter is 1/24th in SD mode.
Steve Benner December 23rd, 2006 03:46 PM
Yes, double check the shutter in SD. I have never had a problem with 24P SD so is there any more info you can provide us with?
Jiri Bakala December 23rd, 2006 06:45 PM
The HD100 defaults to 1/24 in SD for 24fps, which is the wrong setting, it should be 1/48. I wonder if they fixed (changed) this SD default for the 110/200/250.
