Fujinon Wide angle converter
Does anyone have experience with the Fujinon Wide angle converter for the stock 16X5.5 lens?
Does it degrade image quality? How wide is it? any info would be appreciated, i'm looking to get wider angle without spending 13,000 Can on the wide lens ! Thanks |
1 Attachment(s)
The 0.82x Wide converter works well for zoom through, and doesn't seem to degrade the image.
The converter effectively turns your 5.5mm lens into approximately a 4.5mm lens. The adapter can also "live" on the lens and the hood slips right over it. I've attached a field of view comparison of the stock lens with and without the converter, compared to the expensive wide angle 13x3.5 lens. This was based on a real world test, and not calculated, so the adapter doesn't appear as wide as you might think. |
I would agree with Tim on his assessment. Once I put the WA converter on the lens, I've never once had the need to take it off. The stock lens is pretty long, even with the converter on there. I think it's a fair compromise for the price.
Still, I'm thinking more and more of the 3.5 lens to obtain the better glass and those nice high-end wide angle images that my clients tend to crave. It's either that or a new GY-HD200, now that its release is imminent.... What to do.... |
I've only taken mine off one time since it went on...
I needed just a touch more zoom. I couldn't justify the cost of the real wide angle, but it was pretty easy to talk management into a few hundred bucks for a little bit better wide end. Plus it can be replaced a lot cheaper than the full lens so it could really save your bacon someday if you didn't have a clear filter living on the front of the lens anyways. |
I like it!
If your on a small budget, like me, it's about the best thing for a little wider shot, not much mind you, just a little.
Jon |
Thanks alot guys, very much appreciated !!
Another question *does the converter also add to the telephoto as well as a wider angle?* |
No, the wide angle adaptor makes both the tele and wide ends of the lens wider.
So what's the street price on this baby? From the sponsors of course...
http://www.bhphotovideo.com/bnh/cont...ughType=search |
| All times are GMT -6. The time now is 07:32 PM. |
