24p and Motion Smoothing
Hi Guys -
I am shooting a short film on Saturday in 24P and after the tests that witnessed a lot of strobing, I plan on turning on the motion smoothing feature, as recommended in the JVC Handbook. Any suggestions on shooting in 24P with the Motion Smoothing feature? We have movement and dolly shots planned. Thanks. |
You better test it before you choose to use it. You won't see the effect of motion smooth until you play the tape back.
Personally, I avoid using it because it essentially creates "double-exposures" on each frame. The CCDs capture 48fps, every two frames are cross-dissolved and combined into a single frame before being written to tape at 24fps. |
Okay...
Okay...but how do I prevent the jitter/strobing that takes place in 24P. I was following the handbook and it says to turn it on.
If I didn't use it, what settings should use to cause a film-like look at 24P with little to no strobing. Thank you. |
Maybe a slower shutter speed to create a blur with the motion ?
This is not my camera, but I am curious what will be said about resolving the issue you have. But part of the problem may be resolved by slow pans and dolly shots. Why do you have to shoot 24p. Going film out ? |
Hi...
We wanted the film-look to it. Should we shoot in 30p and then covert to 24P using magic bullet?
Are you literally doing a film transfer? |
24p
I'd suppose it'd be for the look and softness of 24P.
Web
Web delivery only.
If it's web delivery only then I'd use 24p. There is no barrier to a 24p WMV, Flash or H.264 workflow (depending on NLE).
If it's to DVD, I'd choose the simpler 30p workflow. |
Great...
We're definitely going to use 24p...but what about the strobing....
should we turn on the motion smoothing as the JVC handbook suggests or should we shoot without it and just use plain 24p with 1/48th shutter speed? Thank you. |
hi
The strobe was in the 24fps AVI... and I viewed it on an LCD.
This is going to be shot for the Net so I suppose I have to keep LCDs in mind. |
and...
Adding to my last comment, which you gave me an idea...I rendered it out as ITVC (or something like that) at 23.96 fps and the strobing was greatly reduced on an LCD. It looked pretty good w/out the motion smoothing at 24p.
WIth 24p you can't just throw motion around the frame like you can with video, you have to treat it very carefully because of the extremely low temporal resolution. I suspect that's the cause of your strobing.
| All times are GMT -6. The time now is 12:42 AM. |
