2 Questions For Ya'll
Hi,
I have two questions. 1. Any news on when FCP5 will support HD100 24P? 2. Is there a way to edit realtime with HD 24p footage? It seems like i have to render everything everytime I import a clip into the timeline. Thanks |
1) nobody really knows when or if FCP will support 24p for the HD100. The rumors are all over the place on that one.
2) If you don't need the audio, capture 24p footage with the AIC 720-30p codec, then use cinema tools to conform the frame rate to 29.97 You won't need to "render" your video files after doing this as long as your timeline settings are correct and match. If you need audio with your footage, you need to purchase Lumiere HD, this is an external capture program that everyone is using. |
Brian,
don't know about FCP ... I'm also still waiting. one FCP trick I didn't know until recently: when you want to edit any format in a timeline set for another format go to the RT button on the left side near the sequence tab on the timeline and change the setting from Safe RT to Unlimited RT . This will allow you to make edits in RT with several different formats of video (or HD24p in a HDV30p or AIC30p timeline) without having to render at each new clip or change in the sequence. I wish I knew about this earlier.... having probably doubled my editing timeload on the last few projects.. oh well |
FCP update 5.1.2 with 720p/25 & 24 unveiled soon?
There is a new JVC Highway brochure - anouncement of FCP update: Now with Final Cut Pro 5.1.2 (available soon as
a free software update for registered owners of version 5.1) Apple has added support for native 720p/25 and 720p/24 editing, as delivered by JVC’s ProHD camcorders with their natively progressive HDV engine (HDV1).... Whatever "soon" means... The german site of jvc quotes this. Look at: http://www.jvcpro.de/highway/imgserv...ighway2_en.pdf |
For example, if you make an edit in the middle of a GOP, the NLE will have to calculate the progressive transformations to get to that frame. If you need to apply color correction or other filters/transformations, this will turn into a pretty heavy toll. When you export from FCP to QuickTime making a reference movie, operation that usually should take just a couple of minutes, FCP has to uncompress and recompress your footage. This, depending on your machine and the length of your sequence, can take a few hours. On the other hand, if you convert your clips, either outside or by selecting a differenr compressor in the timeline, to a better codec, like AIC, then all the transformations and edits will happen to "real" frames. This will improve the response time of your machine and exports will happen in a fraction of the time because all that FCP has to do is to create a QT file with pointers to the already rendered clips. |
However, I have experimented with AIC and I'm not happy with the some new artifacts it produced in my hand held images. I do grant that HDV isn't the greatest with hand held images either but the addition of more artifacts isn't exciting. I have avoided 24p for the most part and have mostly been shooting and editing 30p HDV realtime on a MacBook Pro and the clients are happy with the "film look" 30p creates. |
Here Is My Scenario:
I shoot 30 minutes worth of 24p hd to my DRhd100. The files are all M2T files. I use AVID Xpress Pro HD and MPG2 Streamclip. How should my workflow go?
Can anyone please fill in the blanks without saying the "C" word (ie., capture). thank you 1)First...._________________________________________________________ 2)Then...._________________________________________________________ 3)Then...____________________________________________________________ 4)Then..._________________________________________________________ 5)___________________________________________________________ 6)and so on.... |
