-   JVC GY-HD Series Camera Systems (https://www.dvinfo.net/forum/jvc-gy-hd-series-camera-systems/)
-   -   30p vs. 24p (https://www.dvinfo.net/forum/jvc-gy-hd-series-camera-systems/70977-30p-vs-24p.html)
Hayes Roberts July 6th, 2006 04:18 PM
30p vs. 24p
I realize this has been discussed before, but any definitive answers on 30p vs. 24p when content is intended solely for DVD distribution? Setting aside the possibility of 24p dvd players, etc., what is the real world solution? Is it really that much of a difference in "look"? Thanks to all.
Stephen L. Noe July 6th, 2006 04:31 PM
The ease in workflow of 30p outweighs everything when the sole distribution is DVD.
Jack Walker July 6th, 2006 04:43 PM
How about when both NTSC and PAL DVDs are needed, and the video is shot in NTSC?
Stephen L. Noe July 6th, 2006 05:03 PM
In that case then 24p is best, but if the DVD is purely NTSC then 30p.
Tim Dashwood July 6th, 2006 05:11 PM
It is a purely aesthetic choice, but if PAL DVDs are definitely needed, you should consider shooting 25P and then downconverting to PAL and NTSC. It would be the easiest conversion in both cases.
Stephan Ahonen July 6th, 2006 05:37 PM
25->30 is an awkward ratio to convert, it doesn't pull down as well as 24->30. I would actually say shoot in 24 and temporally stretch to 25 for PAL, since the people in PAL world are pretty used to it.
Daniel Patton July 6th, 2006 07:14 PM
Hayes, I don't see anyone asking what system you are using... PC or Mac?
If PC and Premiere Pro then 24P has more to offer (nicer look, smaller file sizes / less frames, better low light, reduced render times, etc.)
If Mac and FCP then 30P might be better for now.
This is assuming NTSC, as mentioned
Or are you using a different editor?
Steve Benner July 6th, 2006 08:43 PM
From what I have gathered (especially from Steve Mullen), unless you are outputting to Film (True 24 Frames), then 30P has more potential to "look like film" than 24P because of the flicker that 30P has. Each Frame Flashes twice a second (60) like film does (48). With 24P to any Video source, it plays back with a 3:2 Pulldown which is not accurate. He has posted threads at great length about this. It is very interesting.
If either workflow doesn't bother you, then I suggesting testing them out. The thing with 24P is that pans are much harder to pull off, as is motion altogether unless you have practiced.
Good luck.
Hayes Roberts July 6th, 2006 09:28 PM
I am using FCP- Very interesting and helpful; has anyone actually seen comparisons or tested this? Additionally, any word on when Apple is really going to deliver? Thanks again.
Gary Williams July 6th, 2006 10:09 PM
Good luck.
Exactly and I have always agreed with Steve on this matter I believe 30p can in fact look very much like film and to tell you the truth I actually prefur 30p to 24p for everything I shoot. If I was going to shoot something that was going to be bumped to film which is not likely, that would be the only time I would use 24p
Laurence Kingston July 10th, 2006 03:13 AM
I still have a few questions regarding 30p:
How does 30p look when played back in a PAL player that converts NTSC? Most PAL players play back NTSC fine, but I am worried that 30p NTSC might stutter in a PAL NTSC converting player.
Should I flag the 30p as 30p with a 2-2 pulldown or just as 60i? I have noticed that at least half of the NTSC DVD players seem to be confused by a 30p 2-2 pulldown flag and try to do a 3-2 pulldown when they see it. This looks terrible. On the other hand, if I flag it as 60i, uprezzing algorythms might not work correctly. I know that my DVD authoring application: DVD Architect won`t even let me write a 2-2 pulldown DVD because of the potential playback problems.
The show "Friends" is shot in 30p. Does anyone know how that show is flagged when it is released on DVD?
Laurence Kingston July 10th, 2006 03:30 AM
I just did a google search and found that "Friends" is shot on film at 30p and released on DVD as 30p video that is flagged as 60i.
http://www.hometheaterhifi.com/volum...e-10-2000.html
"Several TV shows, including Friends, are shot on 30 fps cameras and transferred to video using 2-2 pulldown. Unfortunately, the Friends DVDs are not marked progressive, which just reinforces our point – you can’t trust the flags."
Tim Dashwood July 10th, 2006 06:57 AM
30P or 60i - the players don't care. You can flag it progressive so that some players and TVs will click into P mode, but it really won't make a difference with 30P since the video file is still 60i.
David Jimerson July 10th, 2006 08:26 AM
That depends on what NLE you're using. Using Vegas, for example, the workflow between the two is identical. And a 24p DVD is true progressive, whereas 30p must be encoded as 60i.
Liquid, of course, is not 24p-friendly. But other NLEs are.
So, if you can edit on a 24p timeline and make a 24p DVD, it makes no sense not to do it, ESPECIALLY, if the aesthetics of 24p are what you're after, and are looking at 30p merely as a "compromise." Despite what Steve Mullen says, I've never seen any 30p looking more like film than 24p.
David Jimerson July 10th, 2006 08:35 AM
That is not true. A computer screen or a progressive display (like an HDTV) will display the true 24p frames, no pulldown.
As for standard TVs, 2:3 (or 3:2) pulldown isn't perfect, but it averages out to the right thing -- and every Hollywood movie you've ever watched on a standard TV has used it. I'd dare say they still look like fine, no?
It's harder, but that's part of the film look. Many of the camera movements that we've come to consider "cinematic" come as a direct result of decades of DPs learning how to work with the motion cadence of 24 fps in order to get the best out of it.
30p still has a video-ish feel to it. That doesn't make it bad, nor is 24p the appropriate frame rate for every use. But if the look of cinematic film is what you're after, shooting good 24p is what you want.
