new hd100 - have some ?s
Well I just got my hd100, and I am very pleased with it so far. I noticed it didn't have an "a" at the end of it's serial number, is this normal? I bought it brand new from bh like a few days ago so I figured it would be the updated version.
I tried to induce sse and I found it pretty easy by focusing on a low lit wall and sure enough, it was there. The sse was barely noticeable at 9db but it is clearly noticeable at 18db. I am hoping that this is the current "A" version. I will have a cow if it is not. The camera is pretty impressive however, and I was surprised how well built it is. I am thinking about giving the mic to my dog as a chew toy though ;) Anyways, I hope you guys can give me some feedback about this "A" serial number thing. I thought it was supposed to be added to the serial number but hopefully I am wrong. |
ok, I guess I should do a little research before starting this thread. The camera's serial number has no "A" on it anywhere, but the box clearly says "hd100u (A)" which I am guessing means it's current.
I am happy now. The only way I can make sse show up is by focusing it on a blank wall and turning up the gain. I tried doing it in a normal situation and nothing comes up that I can see. I guess I am always expecting to get a dummy. My next test is to see how bad the CA on the stock lens is. |
Underneath the camera is the Serial Number...Next to it should be the (A).
If not, I suggest you talk to B@H. I can't see any of their JVC's still being the old models. |
there isnt an "a" on the serial number under the camera.
You should definitely send it in asap for the A upgrade then.
in addition A upgraded cams usually have a sticker on the tape door (top center) that says "push here" Very worth it! While on the subject of gain I find 18DB completely useless as its very noisy. 15 DB is not that bad 9 DB is amazingly clean! |
I just found the sticker- DOH I knew there was something up because the box has the "a" on it I actually thought it was apart of the serial number. I am going to play with this some more and post some screen grabs later to see what you guys think. I already have a bunch of scene files loaded on it Such a neat tool! Truly beautiful design. |
Paolo's true color v3 is outstanding.
I shoot just about everything with that nowadays. |
Thank you Mark!
| All times are GMT -6. The time now is 07:47 PM. |
