-   JVC GY-HD Series Camera Systems (https://www.dvinfo.net/forum/jvc-gy-hd-series-camera-systems/)
-   -   pcm audio on hd100? (https://www.dvinfo.net/forum/jvc-gy-hd-series-camera-systems/68403-pcm-audio-hd100.html)
Brian Luce May 29th, 2006 01:35 PM
pcm audio on hd100?
Does the HD100 record in pcm audio?
David Tamés May 29th, 2006 01:48 PM
Take a look at this thread: http://www.dvinfo.net/conf/showthread.php?t=52041
Steve Benner May 29th, 2006 03:29 PM
After reading that thread, all you have to do is recapture everything, but have the Firewire switch set to DV instead of HDV? I use FCP 5, what option must be checked so that video is not looked for?
Steve Mullen May 29th, 2006 05:28 PM
The thread pointed to does not have the complete story. Yes, one channel pf PCM audio is recorded. But, it is very distorted and so is unusable!!!
It must have been either an error in design or an experiment. For example, it being there does allow software to be developed to "get" it.
I wonder if the 200 and 250 will have PCM audio?
