"Blue-ish" Footage?
Hey all.
I'm finally doing my tests with my HD100 and the footage is all blue. I'm using these settings on the camera: Master Black - -2 Black - Normal Detail - Off White Clip - 108% Knee 80% Level - 100% Cinelike - Off Gamma - Std Gamma Level - -4 Color Gain - Normal R Gain - 3 R Rotation - 4 G Gain - 2 G Rotation - Normal B Gain - 3 B Rotation - -3 Black stretch - 3 I will post a clip of the footage when I get it rendered. Any help would be really great. Thanks. |
#2 | |
But seriousy folks, why change your rgb values? If you need a special look out of the colour gain on specific channels, try that in post instead. Also, and I have to presume here, you must white balance with the old white card using the light in play with correct iris and focus. |
Sorry. I'd actually NOT want the footage to be blue. Normal would work just fine. This isn't Traffic, the low bug version. :)
Auto white balance?
Now back to our regular programming.... :) |
#5 |
Sounds like a white balance to me...do you have frames you could post to be able to see what the blue looks like? The sun is blue, interior lights are reddish. You probably have the WB balanced for interior lights, then moved outside and forgot to change the settings. I have orange/red footage that is the same thing, but other way around. Rewhite it in post...just push the color corrector away from blue (on the color wheel). I use Final Cut, so I could describe it there, not in other editors.
#6 |
Sounds like you were using tungsten white balance (3200K) in daylight (5600K)
Tim Dashwood |
#7 | |
#8 | |
Contributor
#9 | |
Am I wrong? |
#10 | |
#11 | |
Next time be sure that you have done all the settings correctly...becuase otherwise you can create negative rumors! :D Thanks for reply... |
#12 | |
I have changed the title of the thread from "Blue Footage" to "'Blue-ish' Footage."
Tim Dashwood |
#13 | |
And thank you everyone for pointing out white balance to me. I've read up extensively on this and now have a better understanding of it. Thank you all. Last edited by Heath Vinyard; March 23rd, 2006 at 10:09 PM. |
#14 |
We're there for you! 3 years ago, I was there with you! Keep asking questions (both of yourself and others), it's the only way to learn more about new things. Experience is the best teacher.
#15 | |
Learning by doing... but I think you american guys know better! |
