Saving scenes
I can't save more than the two oncamera scenes. (Cam1, Cam2)
When I try to save to Ext1-2-3-4, it's change back to Cam1 before I save the new scenes. I checked the SD card, work fine in my digital camera, I can write on it, or erase it. What I do wrong? Laszlo |
It may be formatted differently than the JVC needs. Make sure you are using a blank card, then use the File Management feature on the HD100 to format the card. This should put it back into the proper state.
Everything OK now..... Wierd!!!
Thanks Earl, but I tried that first.
Anyway, yesterday, when I tried save the scenes files, I realized the camera do not power off. I need unplug the battery to shoot down power... Later I unpluged the camera for about an hour, and gueass what... Everything OK, now the camera shoot down properly, also I able to save any four extra scen files on the SD card. Wierd... very wierd. Also scary May I need upgrade the firmware?? I never had any problem (including SSE) since September when I bought the camera. What I need to do?? Laszlo |
| All times are GMT -6. The time now is 10:46 PM. |
