Can the split screen problem be fixed in post?
Obviously adjusting the video level of one side of the screen would be easy for most editing apps, but does it work satisfactorily? Is anyone doing it?
Bill, the best thing is to learn how to work around the split effect. It's not really difficult and with a little of basic video and cinematography knowledge you can easily do so. I have been shooting with the camera for a while now and I haven't yet found a situation where I couldn't get around SSE.
That's one of the things, but SSE doesn't only show up with gain or in low light.
Sometimes it goes away or lowers substantially after the camera is warm. Sometimes it goes away if you play around with the iris. Other times if you just slightly move the camera or change the angle in relation to your key light will affect it too. But honestly, if you need a stealth type of camera for shooting extreme low light stuff where a nightvision would be more useful than a camcorder, the HD100 is not your camera. You will be better off with a PD170. |
Luckily it happens exactly at the 50% across the frame, so it is easy to duplicate the clip onto a new video layer, apply a 50% crop and then slightly adjust the black levels until it looks the same. Under some conditions if preset white balance was used, one side may have a slight magenta tint to it. This is also very easy to compensate for in most NLE colour correctors. The only complication is when it "flickers" in and out in under some conditions. This would complicate things. However, because of the conditions it seems to present itself, I find it much easier just to crush all the blacks a little bit - which is what I would normally do anyway. I hate milky blacks. |
Otherwise, no technology currently exists. |
Well look. For all practical purposes the SSE will never show up. The only time I can make it show up is on a flat wall, stopped down so that the resultant exposure is under 10 IRE.
Nate Weaver and I (and I'm sure others) have been successfully using the camera for paid gigs and the SSE has never been a problem - even in low light. I am always on the lookout for it, but it is quite easy to spot in the viewfinder, so it never worries me. If you want to be able to run & gun shoot and not think about it, then the camera probably isn't for you. In that case you should stick to a prosumer camera with some auto features and never look back. If you want the next best thing to the look and style of shooting super-16, then the HD100 is right for you. If you don't believe that the camera is capable of shooting in low-light on 0db, then just check out Nate's latest music video. His only sources were a couple 2x4 kinoflos and the shutter speed was never brought down below 1/48. (I think the foot stomping was 1/100) http://www.dvinfo.net/conf/showthread.php?t=55111 |
If by "adding texture," you mean a stucco wall, then no that won't make a difference if the pattern is consistent. However, use a cookie to break up the flat light, or stick a subject in the frame and it may just magically go away. I forgot to mention before that I found on my camera if I set the master black to -3 I can't prod it into showing up at 0 to +6dB. I'm not sure if Nate crushed his master black on that music video, but I'm pretty sure he crushed some black on the final colour correct. I saw some of Nate's original shots in HD before colour correction and there wasn't a sign of SSE. |
Fixing one frame is one thing. I took dashwoods advic and tried shifting the blacks and correcting the split screen. It does help improve, but not necessairily eliminate the Split Screen entirely. One frame took me a several minutes of tinkering with the perimerters. Imagine doing several hundred frames if the Split screen is up for several seconds. For me it isn't worth the trouble of correcting something that shouldn't even be there in the first place.
If it was one parameter (Black level) it could be key-framable. Likewise, it seems to be red that may differ -- so a red balance control would be a natural. Also could be key frameable. Could do RGB, too. This is a near trivial routine. A smart routine would find black and white objects that cross the split and compute the correction. |
