-   JVC GY-HD Series Camera Systems (https://www.dvinfo.net/forum/jvc-gy-hd-series-camera-systems/)
-   -   JVC GY-HD100 can record 720/60P? (https://www.dvinfo.net/forum/jvc-gy-hd-series-camera-systems/43179-jvc-gy-hd100-can-record-720-60p.html)
David Gomez April 18th, 2005 02:54 PM
It states the following from camcorderinfo.com....
"In addition to this the camcorder can record 720/30P, 720/60P, 480/60i, and 480/24P."
I thought it was only able to output 720/60P. Is that statement accurate that it can also record 720/60P?
Don Crockett April 18th, 2005 03:40 PM
720/p60 output
720/p60 is output only:
From GY-HD100U features page:
http://pro.jvc.com/prof/Attributes/f...&feature_id=01
"Live 720/60P analog component output"
From U.S. announcement press release:
http://pro.jvc.com/prof/Attributes/p...&feature_id=08
"In addition to providing HD true progressive 24 P superior quality recordings, the GY-HD100U outputs uncompressed 720/P60 HD, making it ideal for live broadcasting, remote news and POV applications. An optional module converts the uncompressed signal to HD-SDI for use in a variety of user environments."
Murad Toor April 18th, 2005 04:52 PM
Could a JVC 30K D-VHS deck record that 60p signal? I would hope so. :)
Barry Green April 18th, 2005 11:50 PM
Definitely not. I asked one of their Japanese engineers that directly, and they unequivocally said "no".
Heath McKnight April 19th, 2005 08:42 AM
I like the uncompressed HD-SDI.
heath
Mathieu Bergeron April 21st, 2005 03:25 AM
Uncompressed from compressed?
Does anyone know if the video from the uncompressed analog output has been through all processing (even HDV encoding) or is it straight from the CCD at let say... 4:4:4?
Mathieu Bergeron April 21st, 2005 03:46 AM
Oops
Sorry about that... it's been answered here
http://www.dvinfo.net/conf/showthread.php?t=43308
Still wander if the 4:2:2 signal has been through a lot of processing? I have a GY DV500 and it's analog output is derived from the compressed signal wich is of no use for high quality recording... Just want to make sure it's not 4:2:0 compressed brought back to 4:2:2 uncompressed!
Joe Hudson April 25th, 2005 07:06 PM
720/60i
what's the problem with 720/60i ? isn't it the same bandwidth as 720/30p ? it sure would be useful to have it recorded to the onboard recorder so why doesn't the HD100 support it? could it be a firmware upgradeable feature?
Barry Green April 25th, 2005 07:15 PM
There's no such format as 720/60i. In HD, all 720 is progressive always, there's no interlaced version of 720.
Joe Hudson April 25th, 2005 07:42 PM
ah, ok, cheers Barry. shows how much I know. still it would be useful for a more live look...
Barry Green April 25th, 2005 08:21 PM
Well, actually, that's what 60p does for the 720 mode. 720/60p gives the same live/reality look that 60i does in NTSC. Well, better actually because there's no interline twitter or flicker or comb artifacts, but the point remains: 60 samples per second = "reality" images.
Michael Maier April 26th, 2005 04:36 AM
Interesting question. I wonder the same thing.
Steve Gibby April 26th, 2005 08:27 AM
Tech companies will quickly produce affordable accessories to function as workarounds for utilizing the HD100's uncompressed analog component output. Where there is demand, someone will step up to fill the need.
The existing component to HD-SDI converters were designed for larger cameras, and they're very expensive. A stop by the Miranda booth at NAB illustrated that. What will be produced shortly by other companies that service the more affordable product market, are inexpensive component to HD-SDI converters that are small, thus very suited for use with the HD100. If the same converters also had a Firewire bus and the ability to compress the uncompressed component input to HDV 720p60 for output to an affordable clamshell HDV deck that could record in all the resolutions and frame rates of the HDV spec, including 720p60, the user of the converter would have two pathways for using 720p60 from the HD100:
1) Pass through 720p60 4:2:2 uncompressed to the small converter mounted on the camera, output the HD-SDI from the converter to a computer, with a raid array, and multiple TB storage. Computers are getting faster every month, raid arrays are getting more capable, and storage in TB is plummeting in cost. For certain projects and budgets this would be a viable workflow.
2) For mobile production of high-speed sports, reality, etc, the compressed HDV 720p60 4:2:2 (or 4:2:0) output of the converter via Firewire (mounted on the camera) would be recorded to tape on the clamshell deck, or a modified Firestore HDD, worn on a belt pack. The footage would then be available for non-live posting, including enhanced ability to do slo-motion and compositing. The clamshell deck or Firestore HDD would obviously have many other production uses. One use for the clamshell deck would be exactly the workflow I've been using for network television POV shots: lipstick cameras wired to clamshell decks in protective backpacks. There will be affordable 720p/1080i lipstick and cigar cameras on the market shortly.
This week, after seeing ADS Technology release an affordable, small component to SDI converter, I e-mailed the tech staff at ADS with my suggestion for the mobile, affordable component to HD-SDI converter for use on the HD100. They thanked me profusely for the suggestion and indicated that they would be analyzing the possibilities on that real soon.
