FCP and the JVC GY-HD111e
This must have been discussed many times elsewhere on this forum but for the sake of a complete newcomer to HDVpro could you bear with me? Basically, is it now possible to import HD footage from the GY-HD111e (from its tape or hard disc drive) directly into Final Cut Pro 5.1.4 without problems, and then edit successfully? If not is it necessary to upgrade to FCP 6? I've read elsewhere that the JVC HDD might need a downloadable upgrade to achieve the above as well. Any help or advice gratefully received because I am planning to buy this camera very soon and use FCP for editing.
Many thanks Simon |
There are no problems importing from the hard drive (DR HD100 I presume?). Just set the drive to record as Quicktimes and import them to your media drive. This is the most efficient way to use this camera.
Some people report audio problems when recording HDV 720p to Quicktime. This is overcome by recording as M2T and using "Clipwrap" to rewrap the files as Quicktimes. (See top of this forum for "Clipwrap"). FCP 5.1 can be a little difficult. In "User Preferences" you need to change some settings. Switch off "Abort Capture On Dropped Frames". Set "On timecode break" to "Warn After Capture". Set "Pre-roll" to the minimum setting of 00:00:01:00. With these settings you will still lose a second or two between each shot, so allow for roll up time when shooting. Some people still reported problems, it may help to disconnect all Firewire devices other than the Media drive and camera. I also use a use a 4 drive raid array connected via Firewire 800, and never had problems using a G5 2.7 Power Mac. Final Cut Pro 6 allows you to import HDV as ProRes files via the Firewire. This works well, you will only lose about 6 frames between each take and original timecode is retained. ProRes will give you a much better editing experience but you need to make allowances for the larger file sizes. (Works with G5 2.7 Power Mac). Finally when connecting Firewire cables between devices always make sure all the devices are powered down, there are a lot of reports of blown firewire ports that are relatively expensive to repair. Phil Balsdon www.steadi-onfilms.com.au |
Many thanks for the info Phil.
Cheers Simon |
Hello again Phil,
Is it possible to successfully import footage into FCP 5 or FCP 6 directly from tape in the GY-HD111E and the GY-HD200 series cameras as opposed to using the hard disc drive, particularly with the 720p/24p setting? We would like to use tape where possible. Many thanks again Simon |
Yes it is.
Many thanks Liam; are there any special settings in FCP 5.1.4 (or FCP 6) and on the camera that need tweaking first to import tape recordings successfully?
All the best Simon |
I've got it working by using ProRes as an intermediary but it is NOT plug and play. More like plug and PRAY it works. I generally need to boot about 8 times before FCP recognizes my camera. I AM using external FW drives so that may be causing a conflict. I also cannot upgrade QuickTime (7.4.5) or FCP (6.0.3) until I finish the project that is in the edit bay (and has been since last June) so I can't give you any advice on whether new QT or FCP updates may have solved my problems. |
I only had to use FCP 5 for a couple of imports before upgrading to FCP 6. I found adjusting the FCP settings as per my earlier post caused a loss of only 1 - 2 seconds of footage between camera takes. If you use the default settings you'll lose more like 8 seconds.
Button on and leave plenty of roll up before action and a few seconds after, takes me back to the late 1970's and BVU tape. Some users reported breaks during the middle of takes, I never had this problem using a G5 2.7 Power Mac and Lacie 1TB (4 x 250Gb) RAID with FW800. It really is worth the FCP 6 upgrade and ProRes import path if you can. |
| All times are GMT -6. The time now is 12:16 PM. |
