-   JVC GY-HD Series Camera Systems (https://www.dvinfo.net/forum/jvc-gy-hd-series-camera-systems/)
-   -   Problem when turning on HD 100a (https://www.dvinfo.net/forum/jvc-gy-hd-series-camera-systems/121890-problem-when-turning-hd-100a.html)
Ron German May 18th, 2008 01:07 PM
Hi
My HD 100a has been used very few times. But once a month I fully discharge my 3 bateries (438) and charge them. No problem until last week.
When I tried turning on the camera, it started to flash tally light as well as rec and HDV / DV lights and didn`t turning on.
This happen with battery and DC.
The JVC camera manual says that to "solve" this problem I should turn off the camera and wait. I did it and the problem remained. In my nineth attempt the camera turned on normally.
Well, since then the problem has always ocurred and the number of attempts to recover the camera (turning it off and on latter) normal behavior has varied ramdomly.
Have anyone had this problem and knows its source and how to solve it?
Thank you for your attention.
Ron
Ron German May 19th, 2008 07:41 PM
Hello! No one can help???
Ron
Carlos Rodriguez May 19th, 2008 10:02 PM
these posts sounds similar to your issue
http://dvinfo.net/conf/showthread.ph...light=blinking
I'd recommend contacting JVC service.
Ron German May 20th, 2008 12:58 PM
Thank you for your attention Carlos.
Ron
