Time Code Question
Is there a way to have my JVC-110 automatically detect the time code on the tape and pick up from there? I would like to be able to swap tapes and have the time codes match without having to manually enter the new time code..
Yes there is. Just make sure you have 'record run' selected. The switch is on the side of the camera under the lcd. Also, make sure you hit the 'RET' button when you insert a new tape.
Hope that helps. |
