-   JVC GY-HD Series Camera Systems (https://www.dvinfo.net/forum/jvc-gy-hd-series-camera-systems/)
-   -   JVC 250 720p vs 1080i (https://www.dvinfo.net/forum/jvc-gy-hd-series-camera-systems/112923-jvc-250-720p-vs-1080i.html)
Ron Edwards January 22nd, 2008 03:30 PM
I am looking to purchase the JVC GY-HD250. My editing software does not currently support 720p. My understanding is I can use the DR-HD100 recorder with the JVC 250 and record in 1080i.
Can any one confirm this?
Ron
Adam Grunseth January 22nd, 2008 03:53 PM
I use the Firestore HD100, and as far as I'm aware it doesn't record 1080i. I believe it just records whatever the camera feeds it.... so if the camera is feeding 720p it records 720p. Perhaps if you connected it to a camera that fed it 1080i it would record that, but I do not believe it converts between formats.
Just curious.... what software are you using that doesn't support 720p?
Adam Letch January 22nd, 2008 06:36 PM
The HD250s don't record 1080i
to tape, nor do they output through firewire, max is 720p, but they do have a feature where they can convert 720p to 1080i output via the built-in HD-SDI and component analog terminals.
from the spec sheet:
1080/60i: 74.25/1.001 MHz (4:2:0 component, up
conversion only), 1080/50i: 74.25 MHz (4:2:0 component, up conversion only)
You can do a easy upconversion in your NLE, 720p scales well to 1080i. 720p temporal resolution is better though.
Ben Lynn January 22nd, 2008 07:56 PM
Ron,
What editing software are you using? I wouldn't let the software limit your camera choice. I'm using vegas and it cuts 720p and 1080i without a hitch. And I know that there are a lot of other editors that do the same for not much money. Let us know what your using.
Ben
Maxene Kuek January 23rd, 2008 12:37 AM
Premiere also supports 720 p (liscensed from Cineform)... Our experience is that Cineform works GREAT... While a little expensive, it is well worth the $$$
Tim Dashwood January 23rd, 2008 03:38 AM
Originally Posted by Ron Edwards (Post 812476)
...My understanding is I can use the DR-HD100 recorder with the JVC 250 and record in 1080i.
The product you're probably thinking of is Convergent-Design's Flash XDR.
Ron Edwards January 23rd, 2008 02:24 PM
Update
I am using the Macro Systems line of editors, CASABLANCA.
These editors will do simple straight cuts on 720p but all the special effects will not currently work. I have a ton of software that works great but if I change software then I also have to change hardware. Besides expensive I would have to learn all new software.
If I could get the JVC 250 into my editor at 1080i then I would not have a problem. Someday I think Macro Systems will fix the 720p interface problem.
I was hoping a hard disk drive would make the capture at 1080i and solve the problem.
Ron
