PC capture problems of m2t files
Hi there,
My Pc, Windows Xp SP2 updated, doesn't capture m2t. files (SD format)from my JY HD-10u. It recognizes the camera and works properly in the DV mode but not in the mpeg mode. I have already tried the following according to the tips I received in other forums: -switchted from "auto" tp "SW" in the menu of the cam. -de-reinstalled the JVC device driver several times. - the original hd capture utility software 1.0 doesn´t recognize the cam at all, neither does the Cineform HD link - the mainconcept mpeg encoder 1.4 does handles the cam without preview and does not capture any frame. SO????????? I have no clue what is going on here. I have a single processor 1,7, and 1GB RAM. Can anybody help me please!! Thanks a lot. Regards Marc |
Though under SP2 this SHOULD not be neccessary - did you already try to install the drivers for the camera manually?
I need to do this on my notebook with XP and SP1. And maybe this also helps you out. How to install the driver should be listed in the manual. Marco |
Try to do the same thing using Connect HD (trial version).....
Just to decide if is a driver or software problem... Sulu. |
Marc,
I also have problems if I haven't imported HDV footage to my XP box in a while. Make sure the switches on the outside of the unit are set to the following: - recording mode switch is set to HD - playback mode switch is set to Video - set i.Link out to MPEG2 - in the camera software settings, make sure i.Link out is set to SW - connect your firewire cable to the PC up BEFORE starting the PC - switch the cam on AFTER you've logged into XP so that you can see the JVC Tape Device come up scott |
| All times are GMT -6. The time now is 07:42 PM. |
