Dark output
I'm new the forum and have received my GR HD1 a while ago. I've been trying to get to know it better.
One item I dont know if its the way it is or not, the LCD shows the scene pretty bright but when I play it directly on the TV or on the PC, it is very dark. It looks as if gamma is incorrect. Is there anyway to get the picture to show what it looks like on the LCD? Im playing back directly with component, Svideo on the TV, on the PC I'm playing back with Windows media (using RemuxTS) and Adobe Premiere 1.5.1. |
If you PC and TV are calibrated (both equally dark) so you know that isn't the problem, reduce the brightness on the LCD untill it matches the same level as your TV/PC display, then add more light for your shoot.
Thanks for the reply, Ken.
Im just curious on the fix as you suggested. I havent held a camcorder since a old model Sony Hi 8 cam. Why would the LCD give a false reading of what is on the tape? My Sony tv is plenty bright and the video from the cam is still dark. The thing I dont understand is if this cam does not have good low light sensitivity, then how does the LCD show a picture that is supposedly from the same sensors? I would have thought that the LCD has a pretty good estimation of the actual video on tape. |
The LCD, just like your TV has a brightness controll and it appears to be cranked up as it is showing to be brighter then your footage. What level is it set to?
On bright days you might want to up the brightness on the LCD to help you see it outside. Otherwise you will want it set to a lower level that matches your footage. |
The LCD brightness is in the default middle position. Even with it all the way down, the LCD is still brighter than the output to my TV.
Well something seems odd. How is it through the viewfinder? Same as LCD or not?
The problem here is the issue of setup level. Most new digital camcorders output a signal that is equivalent of 0 IRE. NTSC setup is 7.5 IRE standard. Therefore, your picture will look too dark coming through the s-video or rca video jack.
You should be able to capture to your pc, burn the video to DVD and play it back with no problem. Why? Because the DVD player knows to add the 7.5 IRE setup to the output signal which will 'lift' the signal luminance to what it should be for your tv set. Your camera's vf is giving you the most accurate picture. Some cameras will allow you to shift the setup level for output only, but most that have adjustable setup level will adjust the recorded signal which is not what you want. Try the method I suggested above and see what you think. regards, -gb- |
I thought that it may be due to the 0 IRE and 7 IRE differences but also thought the JVC would be modern enough to compensate for this with Svideo or component. I tried the straight output on my Benq 7800 projector component as well as my Sony 36HS510 (Svideo) but both came out dark.
I suppose theres no way to get the cam to compensate for this difference? This cam was purchased from B&H, so I assume its for the NTSC market. Why would they sell a cam with outputs that are at 0 IRE and not the 7 IRE NTSC standard? My main issue (before trying the DVD method) is that its also dark on my PC. I cannot turn up brightness without distorting everything. I use a nVidia card (6600GT), is there a way I can tune this in Premiere? |
The IRE issue may cause some issues crushing some blacks, but it won't make the whole screen darker. I don't think that is your problem. It never has been for me (HD10)
Can you ever make the output bright? Is it always, always dark? Even outside on a bright day? Are you shooting Auto or Manual, and if so are you using any presets or locking your shutter very high or locking the exposure to low? Are you using any filters? |
What I did to test this is to hookup my HS510 as the monitor through Svideo.
While indoors, with the cam on and pointed to a bright sunny window, I can see that what I see on the LCD (not vf), is much brighter than what I see on the monitor. The colors are muddy on the monitor. I only use a UV filter at this point but do have other filters. This is the part where I'm thinking why isn't it as brighter? It seems that what I see on the monitor is what ends up on tape - dark. My videos are indoors right now because of my newborns. While I thought theres plenty of sunshine coming in, I would be surprised to find that the cam's playback would be very dim on the PC or with monitor. It is near black and I wouldnt be able to edit anything unless I added gamma adjust to each clip. I will try to look in the vf tonight to see how it compares to the LCD. So my areas to look at are LCD vs VF, IRE level, or simply this cam really needs it's 30 lux. |
I'm disappointed, I guess, to report that the VF output is the same as the LCD. Nice n bright.
I also tried to un-pin the 7.5 IRE in Premiere and it made no difference. IRE 7.5 is default to on with my HDV capture. The only fix is to set the gamma at a default of 10 to 8 or 7 to get the picture to lighten up at the proper level. Is there something wrong here? |
You never mentioned what settings you had set. This cam needs light and the LCD may be showing it better due to its brightness level. Please do shoot outside and let us know your findings, but at leasat tell what mode settings you are using for you indoor tests.
Sorry I didnt indicate it but in my previous message it was my thought after shooting outside.
Outdoors in auto mode Output on my PC and monitor is dark but not as dark as indoor due to the brightness of the sun. It is like turning down brightness while contrast is up on a monitor. If I corrected the gamma on Premiere from a default of 10 to 8 or 7 , it restores what it should be. At the same time, the edge enhancement diminishes. So I know that the camera is doing this. I will try the same shoot again today with shutter lock at 1/30, then exposure lock. I believe the cam just naturally takes in dark images and what I am seeing is correct. Its just disappointing to see how much light it needs and that it still darkens the image even when Im out in the sun. I think most interprets this darkened image as edge enhancement because after a gamma correct in post, it looks fine. Let me just make clear that after burning the clips to DVD, the image is brighter however not as bright as the LCD/VF. I found that the brightness between the LCD and VF to be pretty close. But neither matches what I see on tape in playback on the PC or TV monitor. I believe that the HD10 may not show this issue that is on the HD1 since many report that the HD10 doesnt have the "edge enhancement" as the HD1 consumer model does. |
It could still be a technical problem but give this a try first as my feelings are that the cam is not defective.
I would recommend doing some shooting with the exposure locked. Leave the cam in a set position not aiming directly at a light source set to manual mode and lock the exposure. Don't make any other settings (do not attempt to lock the shutter). Record and adjust the exposure while speaking into the cam so you can verify how each setting looks on playback. This would best be done outside, with ample light. If you do it indoors do not aim at a window or such(too bright) and turn on as many lights as you can. Did you check to make sure no presets were selected (program auto exposure)? Having any of the presets selected can have a major impact on image. Sports mode for example will up the shutter making the image dark. Snow and Spotlight will as well affect image. Also make sure the backlight isn't selected. |
Outside shoot
- Manual 1/30 is the best. Video playback is almost as bright as LCD, under sun light. - 1/60 darker with sun light but panning is smoother - as expected. - Exposure lock - I guess it works when you first lock on a specific exposure. Looks like its never intended to go from bright to dark. My screen turns all black. Seems to be meant for going from dark-med to bright without overexposure. I guess I can conclude that this cam is naturally dark and requires lots of light. Still I have this feeling its within the cam's ability to be able to get the right brightness with a bump or two in the gamma area. |
Quick Note!
Yes, this camera requires a lot of light. But, when it has it, then it is really good!
Have fun, Mike |
Play with exposure settings and leave shutter speed alone untill you are very experienced. Adjust exposure to your liking and make sure there are no auto AE setiings messing with your setup and you should be good to go. Low shutter will give you better light, thats why the cam always reverts to 1/30th in HD. If you take the time to learn the cam you will enjoy it. There is a learning curve. Good luck!
I understand theres a learning curve to this cam. However, no matter what the exposure is at, even at +10L, I am not getting my original dark output resolved.
So, indoors, a bright light source is always needed. |
Allen do you want to get to the bottom of this? Give me some feedback on the questions I ask you and we should be able to figure this out. Hang in there!
Are you saying the exposure control has no effect at all? Hook it up to the TV then test the exposure controll so you can tell from the live feed what works and what doesn't. Are you sure you have no AE presets enabled? Backlight compensation is not selected? Are you in A or M mode? Make it "M" Do not touch or sellect anything to do with shutter! Press the exposure button and rotate slowly. Should be a lot easier to notice these changes viewing on the TV. Any change at all? Lets go from there. |
Correct. From my observation and the thread about exposure lock, I'm not sure how this will help me in indoor shoots? >Hook it up to the TV then test the exposure controll so you can tell from the live feed what works and what doesn't. I believe I tried this and saw that when I jog the exposure dial from 0 to +10, no changes occur in the image on TV or on the LCD. >Are you sure you have no AE presets enabled? None. Always off. >Backlight compensation is not selected? Not selected. I tried this also and saw no difference on the LCD or VF. I didnt try the TV monitor. This is the same as the exposure test, it didnt change anything for me. >Are you in A or M mode? Make it "M" Manual for all indoor and outdoor tests. >Do not touch or sellect anything to do with shutter! I'm off the shutter. Can't play with exposure when I have shutter locked. So I pushed the shutter button until it disappeared. >Press the exposure button and rotate slowly. Should be a lot easier to notice these changes viewing on the TV. Any change at all? I will try this again tonight but the thing I was saying about the exposure was that no it doesnt help because the cam readjusts by other means to get the picture "normal" and dark again. I can see that it brighten up for a second but it readjusts after and the pic looks dark again. Perhaps I'll also include some screenshots to show and clarify. |
My testing
Just did a few shots with exposure adjusted. The exposure does brighten the picture..but as before, even on the TV monitor, it does not provide the lift needed to match the LCD or VF's output of the same image - even towards overexposure.
But I did find a setting to my liking for indoors, even better than auto. Its the "set nothing" mode in manual. No AE, no shutter, no arperture, no exposure lock. I'm sure everything is on auto but it provides a brighter picture than auto or manual in 1/30 mode. It is almost like being in manual with only 1/15 shutter set but without the panning blur. I am not sure what shutter speed it is set at but if its 1/30, its much brighter than actually setting 1/30 in manual mode. To compare, I switched it to auto, and it was darker. In all shots, AGC is on. Its not too bad. Without it, its too dark. The chroma noise exists whether its on or off. The setting seems to be the best setting for a bright picture with indoor shoots. |
Try complaining to JVC. It has been stated by some that newer cams have been improved allowing much better light capability. This was first reported by users who had repairs done and noticed a vast improvement when returned.
Called JVC Service
Their nearest service center is 4 hours away so I have to send it in.
They claim that the cam needs some soldering to restore the brightness. How does this sound to you? |
Surprised they replied so quick and seem to know the problem sight unseen. Any estimate on cost?
Bottom line is if you want a functioning cam?! |
They said as long as I keep a copy of the sales receipt from B&H its under warranty. The lady who fielded the question to the technician said "it sounds like some soldering is needed to fix the connections".
Called again
Called them again..this time I think I got a tech guy posing as a phone operator instead of a real phone operator.
He gave me a different story. He thinks thats how the cam works. Theres nothing wrong with it. "If you (me) want to be convinced, go to Best Buy and try one of theirs. Then decide if your cam is broken or not." I think I will try that. He spoke of the IRE 7.5 differences in lame-man terms but he said that is very subtle and shouldnt a major difference. No soldering needed from this guy. |
