Should i buy the HD1?
Hi
i would love to have a high definiton camcorder. I prefer to take video while i am walking. Because i usually take videos at my vacations i dont want to buy i big camera like sony fx1. So my only choice is the hd1 because of the small size. How is the image quality with this camera if i take video while i am walking. The night shots will be equal to my sony dv camera trv70 (lux 7)? thank you |
Get used HD10 on ebay instead. HD1 and 10 rated 35 lux.
Hd10
For the money I am a huge fan of the JVC jyhd10. I also own an XL2 and use both for my video production company. Mainly event videography. If you are willing to really put the time into learning how the JVC works it will yield fantastic results. If you are looking for something to set to AUTO and run and gun, I would suggest another camera. When I work with the two cameras side by side it amazes me the quality of footage that I can get from the JVC. For the money I would highly recommend it. Just be prepared to experiment alot and visit forums like this to help you along, the manual like most cameras in this class is really sparse. I would buy another JyHD10 for sure.
If you're looking for a low-priced HD camera, definitely go for the HD1. I have one and would get a new one any time. Don't get confused with all this talk about the new cameras (Z1,HD100U,HVX) - sure they're great, but they're also expensive and bulky.
The HD10 is only slightly better, the main differences being the higher res viewfinder, XLR audio inputs, and less edge enhancement on the video. |
thanks for your reply but you didnt answer my questions about image quality shooting while im walking and if i could take videos with low light.
Shooting while walking doesn't depend on the camera. You are better off getting a soulder support or steady stick if you want more steady images. Is that what you mean?
As to low light, I don't know the Sony you mentioned, but the HD1 is a 1 CCD camera so it's not the best under poor lighting conditions. However personally I found it to be much better than most people say, almost as good as my GL2. I can post a couple of stills taken in low light if you want. |
i asked about shooting while walking not for how is the stabilization of the camera, but for the image quality, does it blurs? i saw videos of fx1 (cineframe mode) and even with a small movement the image had blurring.
3300 euros for buying fx1 is too much for me but 2000 for hd1 its much better. thanks for your replys |
I think if you know how to hold a camera fairly steadily you can shoot footage while walking. The JVC camera has an advantage over the Sony and I don't think it blurs as much as the Sony does when you move it. This is because it uses a 6 group of pictures compression codec while the Sony uses a 12 GOP compression codec. The Sony compression codec may be more efficient but their is a perfomance loss when it is used.
The low light perfomance of the JVC camera is not as good as the Sony camera however a lot of times you may think that you are shooting in low light but actually you get too much light into the camera and overexpose the image. |
The HD1/10 doesn't blur when you shoot with it while walking, but the video is very jittery at 30fps with unsteady holds. I wouldn't recommend shooting with it while walking. When I have, it's jerky looking despite my best attempts. My HD1 prefers a tripod, or a very steady hand. The optical image stabilization is not very good in my opinion.
And then perhaps I misunderstood your intended use. Taking the HD1 along for strolls is fine. Shooting while taking steps is what I would avoid.
I have FX1E. There is no objectionable motion blur. Try it. You'll find out same. Ideal camera for him may be the announced coming up smaller Sony HDV, or coming up Canon, or whatever with 60 Hz shooting mode. Radek |
you are wrong, i use my handheld stabilizer and then proceed with video editing using the stabilization plugin of premiere. Then the video is full watchable!!!!. Shooting while walking gives after the virtual feeling (when you watch the video at my 80'' projector) that you are there living the moment.
You probaly shoot with wide angle setting. Chris is however right. You should make your own camera decision. Add some scary music to enhance the famous Blair Witch look. That movie was blockbuster. Just kidding. Try the camera(s) in store. Walk with it with your stabilizer, see which camera you like.
Radek |
Speaking in general terms, the guy who wants vacation shots and is not a pro (again, not Yiannis in particular), will not have a stabilizer or shoulder support. I'm pretty sure I'm right about that. It's good to see that Yiannis has one, of course.
In general terms, you are probably correct.
In my case, I will be carrying a Sony HDR-FX1 on vacation to Greece in June. While I always carry a tripod so I can get into my own shots as well as get steady shots, I also have found that there are places where a tripod is not allowed. Like Chichen Itza in Mexico. Either because the guards have decided that a tripod means you are a professional and need a license to shoot, or because they do not allow tripods at all since some people don't know to make sure they do not scratch the floor. So for those occasions, I will now also be carrying the DVRigJunior. To avoid shaky shots. I get a little smoother shots when moving because of the smooth spring loaded suspension support pod, but not as good as a stabilizer for walking. But a stabilizer works because of the weights. And climbing innumerable steps with the extra weight is not a viable option. I believe that under these conditions, the FX1 is fine, and the JVC would be equally fine. I prefer the footage from the FX1, but unless you compare the HD1 footage to the FX1 footage side-by-side, I think you would be generally impressed with the HD1 footage in comparison to uprezzed DV. |
Steven have you compared footage of an HD10 with an FX1 side by side?
Not side by side unfortunately. Not the same footage anyway. I did have a chance to review a Royalty Free Collection that actually had some pretty decent shots. And the footage looked good on the 60" Sony HDTV.
Let me say that I don't produce for broadcast. If it looks good on a HDTV, then that's good enough for me. When played via the AVeL Linkplayer on a television that has 1280X720 pixels, the HD1 footage looked fine. I thought it lacked the color definition of the Sony, but one chip vs three might have had something to do with that. Compared to a one chip DV camera, it was certainly a huge improvement. |
