-   JVC GR-HD1U / JY-HD10U (https://www.dvinfo.net/forum/jvc-gr-hd1u-jy-hd10u/)
-   -   hd-10 playback issue (https://www.dvinfo.net/forum/jvc-gr-hd1u-jy-hd10u/34258-hd-10-playback-issue.html)
Steven Galvano October 31st, 2004 06:35 PM
A tape is playing back funky.
The timecode is running, but all I get on the LCD is a blue screen. If I fast forward (while playing) I see the image, but it looks kinda screwed up - like what happens sometimes at the very end of the tape.
This has never happened on the 100+ tapes I have recorded with this camera, but it has happened on 2 of the last 4 tapes.
I also (after this happened) used the head cleaner.
Any insight?
Steven
Troy Lamont November 1st, 2004 11:54 AM
Possible tape problem?
Steve,
I would clean the heads again. Also I've found that if you stick with one brand of tape, you're less likely to develop a buildup on the heads.
I would also assume that you have not cables connected to the camcorder during this playback? You can watch on the LCD when the component cable is connected.
Troy
Steven Galvano November 1st, 2004 12:02 PM
I dont think it is just teh heads because it happens with only 2 tapes in particular. Other (HDV) tapes play fine.
Steven
Heath McKnight November 2nd, 2004 02:27 PM
what tape are you using? I recommend Sony mini-dv. But it does sound like a heads issue.
heath
