-   JVC GR-HD1U / JY-HD10U (https://www.dvinfo.net/forum/jvc-gr-hd1u-jy-hd10u/)
-   -   good nd filters for hd1/pd1 (https://www.dvinfo.net/forum/jvc-gr-hd1u-jy-hd10u/31413-good-nd-filters-hd1-pd1.html)
Graham Jones September 5th, 2004 03:36 AM
I'm looking for good nd fliters for my pd1? Physically it's the same as the hd1.
What brands and models are working well?
Graham Jones September 5th, 2004 01:29 PM
For example the Nikon 52Mm Filter Nd4S Neutral Density? Am thinking of ordering it? Is that a suitable choice?
Thanks very much in advance.
Ben Buie September 6th, 2004 12:21 AM
We've used the Tiffen .3 and .6 52mm ND filters without any problems.
Hope that helps.
Ben
Graham Jones September 6th, 2004 01:58 AM
thanks - the Nikon one is the ND I want and the size (52mm) I want... it's just that I can't find anything about it on Nikon's sites. Is there any chance it would be for still photos rather than camcorders or unsuitable in some definite, clearcut way like that? Or is a correctly sixed, correct ND level filter simply correct?
Steve Crisdale September 6th, 2004 07:48 AM
<<<-- Originally posted by Graham Jones Senior : thanks - the Nikon one is the ND I want and the size (52mm) I want... it's just that I can't find anything about it on Nikon's sites. Is there any chance it would be for still photos rather than camcorders or unsuitable in some definite, clearcut way like that? Or is a correctly sixed, correct ND level filter simply correct? -->>>
The choice of ND/Polarizer etc. shouldn't be too much of a problem. Any decent photographic filter will do the job fine. Don't forget they're designed to work with resolutions of 35mm film....so if they can't do the job on a HD camcorder they definitely wouldn't handle shots on an SLR!!! The thread size (52mm) and the thickness (depth) of the filter are the most important issues from my perspective.
Obviously you'd prefer not to use a step-up/step-down adapter, and be able in most situations to use the lens hood.
I was fortunate enough to remember some old Hoya ND's I had that just happened to be 52mm threaded, as well as a Prisma (probably Japanese generic) Polarizer. They work just fine!!
Graham Jones September 6th, 2004 08:12 AM
great - thanks
