how to avoid video shearing
I'm wondering how slow do we have to pan / zoom etc to avoid the video "shearing" effect. And other types of artifacts introduced with any rapid movement with this camera. Or is this camera only useful for still shots....
Special shooting technique must be used, as with all progressive cameras (including film), to prevent ghosting images while panning.
Namely, pan the camera very slowly; or track the subject you're focusing attention on (background will still smear). If your camera is stabilized with gyros (see www.ken-lab.com, for instance), then the gyros will naturally slow down the maximum speed you can safely pan with, making your moves very film-like. Now, *zooming* has nothing to do with this phenomenon - it normally propagates only while panning. |
Why wouldn't this happen with zooming? From my limited understanding, For panning, the motion is nearly horizontal. For zooming, the motion is both vertical and horizontal.
There's no "motion" with zooming. Only lense's focal length is changing. Zoom doesn't make objects move against the camera, thus there should be no visible artifacts like strobing (or ghosting - I still don't know what would be the universally accepted term for the effect).
On contrast, the object crossing the camera's view is changing its position against the camera. Because camera only captures 30 frames per second, each frame registers an object in a different position. The faster the relative movement of object against the camera, the harsher the strobe. Of course this looks even worse with 24p than with Hd10's 30p. Please note that Shutter speed also contributes to the perceived severity of the artifact. With 1/30 shutter, the severity is less than with 1/60 or faster. This is because 1/30 shutter simply makes images blurry, thus "smearing" the ghosting effect to the extent that it becomes less visible. Steve Mullen's HD10 Shooting Guide (recommended!) has a scientific explanation of the phenomenon. |
>There's no "motion" with zooming. Only lense's focal length is >changing. Zoom doesn't make objects move against the camera, >thus there should be no visible artifacts like strobing (or >ghosting - I still don't know what would be the universally >accepted term for the effect).
The motion is the subject moving relative to the CCD array, which will happen during panning (horizontal), tilting (vertical) or zooming (horizontal and vertical). You're describing an artifact that seems to worsen with the frame rate (sampling rate). The artifact that is caused by panning too fast can also be caused by zooming too fast. Another area of videography that clearly illustrates both issues is titling, especially noticable on characters with small features and sharp, high contrast edges. |
Actually, the motion is that of the projected of the image relative to the CCD array. The subject need not move. Likewise, as we've seen to great effect in some movies, one can zoom out and move the camera toward the subject such that the subject doesn't appear to change size/move.
Lisa,
Unfortunately, I don't think your going to be able to find an answer to "how slow you need to pan" here in the forum. I think this is one of those things where you just take the camera out for an after noon and practice and then review your results later. But I really wouldn't spend too much time worrying about the whole thing. Personally I don't think this "ghosting" should be an issue at all. I mean, film cameras have had this effect for over 100 years and no one is complaining. Brad |
It's easy provide a formula for a minimum of aliasing for a particular feature size for a particular video frame resolution sampled at a particular frame rate. However, the result will results in pannning/zooming that is too slow.
The table you want is in my Shooting Guide.
The higher the shutter speed, the less likely you will notice the motion when you pan.
this is true to a point. If you get too fast, you will loose the reality in the picture. I would recommend you use the camera at 100th if a second or 125th of a second. I'm not sure how fast you want to pan, but take a look at TV and film. Not a lot of fast pans unless they use it as an effect (like The Practice for example), in which case, you won't care. DBK |
<<<-- Originally posted by Darren Kelly : The higher the shutter speed, the less likely you will notice the motion when you pan. -->>>
The higher the shutter-speed the WORSE it looks. You want it below 1/60th. Shuter-speed control helps, but pan speed is critical. A super fast pan or a slow pan are both fine. |
1/100th or 1/125 does not look bad Steve, faster than that and I agree, but come one, it looks terrible at 1/30 due to the juddering.
DBK |
The nice thing about digital is that you can see the results of strobing in the viewfinder to an extent, and certainly on playback on a monitor. With film, you don't really get a feel from it in the eyepiece--you just develop a knack for what is the "no fly zone" for pans. Be aware that different focal lengths will affect the pan speed.
As Brad points out, this phenomenon has been present for many years in the film world. However, I have seen too many instances of strobing and I find it very annoying when it does happen, especially watching a movie in a cinema; sometimes I have to look away from the screen. I remember seeing "The Nightmare Before Christmas" when it came out, and was astonished that during the opening sequence, there was an extended pan that strobed terribly, pulling me right out of the movie. I would have thought that the obviously expert animators on that movie would have been conscious that they were programming a move that would have had those results, but...! Just yesterday I was asked to perform a pan across a set simulating a character's point of view; the director was pushing me to get through it faster, but I had to warn him that doing so would risk strobing, and I would have to jump up to double the speed to avoid this. It's a regular occurence. |
Charles, I'm with you.
Last movie I saw in the theaters was Matrix Reloaded. I also was shocked at how stroby many scenes looked. Exactly as you said - I found myself turning away from screen when the effect became real bad! Going back to HD10 filming: of course Steve is right that *faster* shutter makes strobing more apparent, while *slower* shutter makes strobing less apparent. The practical difference is between 1/30 (smears the shot to make strobe less visible) and 1/60 (clear, sharp video but strobing is showing.) Faster than 1/60 shutter makes no difference in 99% of the cases. Remember that frame rate is just 30p *regardless* the shutter. Therefore "amount of reality" captured in any given frame is *not* increasing with faster shutter. As a matter of fact, it is decreasing with faster shutter speeds for the obvious reason (thus more strobing). I did some rather extensive tests on strobing with HD10 camera, and finally decided to go with 1/60, sharp picture, and (unfortunately) some strobing. Of course, strobing is significantly *worse* with film, which has lower temporal resolution (with equal pixel dimensions) due to the lower (24 vs. 30) frame rate. (Of course film always wins in clarity as it's 2000p to 4000p per each frame...) So in terms of strobing, we are in a better position with HD10's 30p than film camera operators. I'd of course wish for 720p60 cameras to arrive... Now that would really increase temporal resolution and lessen amount of strobing, comparing to today's HD10 720p30 - but at expense of DOUBLE the data bandwidth to capture/transfer/edit. Talk about slow real-time editing with 720p60! :) So taken post-production into consideration, 720p30 seems to be tops what we can realistically edit/process at this time using high-end PCs. |
<<<-- Originally posted by Alex Raskin :
I did some rather extensive tests on strobing with HD10 camera, and finally decided to go with 1/60, sharp picture, and (unfortunately) some strobing. -->>> Alex is right. 1/60th is the optimum. Anything higher is horrible. 1/60th is a 180-degree shutter just like film. (Darren, i hope you have this right on your DVD as it is crucial. You have a copy of my Shooting Guide with a detailed explanation of this aspect.) Of course, 1/30th is necessary when light goes too low. Alex is also right about p60. Since the HDV spec. limits 720 to 19Mbps, doubling the pre-compression data rate is going to increase compression artifacts terribly. As will 1080i -- which is also 2X the data rate -- even through the spec allows 25Mbps. 2X the data rate also dramatically increase heat and power consumption. |
Thanks for the tips guys, guess we're just going to have to keep practicing with this fussy little camera to get good results. Its sad but we're finding we have to use our XL1s as back ups because this camera is so difficult to predict on the results.
Why is strobing such an issue? I though everyone wanted film characteristics. What I need some help with is this 24p stuff why would anyone want to shoot video at 24 fps? Do they really think there going to film, but saving money on a $4k cam?
Best advice would be to change angles alot, use cuts. Or as Alex said before track your subject. I don't care about background smearing myself, I love a good track shot. I would like to know how you intend to use a XL1 for backup? Are you shooting in DV mode, or twice? |
hehe, well using our XL1 as back up I mean...if the HD footage is garbage, we give the client only DV. We actually only promise DV right now, and if can get it HD, then great. Its just not very reliable unless you can control the lighting conditions. Both cameras shoot at the same time. (We usually use 2 XL1s and a back up GL1, but now have switched to an XL1 and HD10). I highly doubt we'll ever switch to 2 HD10s. This camera just can't do the range the other DV cameras can do. We'll wait for the next HD camera, but until then this will have to do.
| All times are GMT -6. The time now is 07:36 PM. |
