a possibly dumb question about dv
i dont know if im missing something, but i cant get premiere (or any program) to transfer dv video to the camera through the firewire cable. does it just not allow it? im using a pc and ive tried everything i can think of. part of the video shows up and its garbled and its crap. will this camera just not record to dv tape through firewire?
could some1 at least try transfering to dv from the computer?
helloooo |
It sounds like your PC is having issues with the firewire card. Try re-installing it, and updating all drivers for it and Premiere.
Good luck with it. |
no, cos i have a sony trv-950 and it works fine, i just tested it
Is the DV-MPG switch on the HD-1 in the DV position?
<<<-- Originally posted by David Kennett : Is the DV-MPG switch on the HD-1 in the DV position? -->>>
yes it is |
I'm not familiair with this camera, but here in PAL (europe) land
a lot of camera's have DV-IN disabled because extra fees must be paid for having it enabled (worries that people use it to copy stuff illegal). I'm not sure whether your camera is PAL and might have such a block, but it might be a possability. Can you capture fine? If so, your card etc. is working okay. If using premiere, you might it over so that the monitor is routed over your firewire. No play the timeline and record that. See if that helps. |
I tested the camera with FCP as a Source.
But, alas I didn't try outputting to the camera. |
I have added a section on making DV from HDV using 4HDV.
I asked a buyer of 4HDV to try recording a DV version of HDV back to his HD10. His report: "The camera recorded the "DV from HD" via firewire just fine." So I'm not sure why your are having problem with a PC. |
| All times are GMT -6. The time now is 07:25 PM. |
