-   Jibs / Cranes / Booms (https://www.dvinfo.net/forum/jibs-cranes-booms/)
-   -   The difference between a jib and a crane? (https://www.dvinfo.net/forum/jibs-cranes-booms/86255-difference-between-jib-crane.html)
Paul Jefferies February 11th, 2007 06:35 PM
The title says it all - sorry if this has been asked before but I'd like to know...
Richard Alvarez February 11th, 2007 06:57 PM
The way I use it, and the way I hear it used, the distinction being that a 'jib' is for the camera only, while a 'crane' usually includes a seat for the operator, and quite possibly the AC. or Director.
So a 'jib' is a small 'crane' that can be mounted atop a tripod or other device, and the operator stands on the ground, controlling the camera as it moves up and down.
A 'crane' is typically a larger device, might or might not be self-propelled and powered, that can lift a full sized camera and operator.
The confusion can come in because a 'crane shot' might be performed with a jib. Much like a 'dolly shot' might NOT be performed specifically on a dolly.
Kit Hannah February 11th, 2007 08:02 PM
Yeah, the term "Crane" & "Jib" are used so loosely because most people don't really know what they are. Crane sounds a little bigger. We own a 50' Cammate Series 2000 Camera Crane, which is what Cammate calls it, but really it is in fact a Jib. There is no rider on it, just a camera that is remotely operated from the base of the unit. Richard had a pretty good explanation of it, in his last line about the dolly.
Richard Alvarez February 11th, 2007 08:16 PM
Well I suppose one might say "all jibs are cranes, but not all cranes are jibs" if that helps any.
Probably not though....
Steve Leverich February 12th, 2007 02:33 AM
Outside of the photographic realm, a jib crane is one that has an arm (the jib) that can rotate, raise or lower a load. The Pylon is what the jib rotates ON - for our purposes, the tripod or stand you mount a jib arm on would be the "pylon".
Away from photography again, there are several other types of cranes used for lifting -
http://www.osha.gov/pls/oshaweb/owad...ARDS&p_id=9830
In my "other" job, we usually refer to a "jib hoist" - this consists of a center pylon, usually fastened to a heavy plate which is in turn lag bolted to a heavy concrete floor - at the top of the pylon, there's a bearing that holds a horizontal "H" beam (the jib) on which rolls a trolley that has a small electric winch hanging from it - so you can lift a heavy object, swing it around and/or push it along the jib's length, and set it down in another location.
In photographic terms, I get the impression that the terms are more or less interchangeable by most - but any crane I've seen used for photography would be called a jib crane in the industrial community... Steve
Charles Papert February 12th, 2007 03:31 AM
I would stipulate that a crane can be either manned or remotely operated from a distance from the crane, whereas a jib is manually operated, or if remotely, from the end of the arm.
It is a somewhat technical distinction though. In most cases a jib is a short crane.
