New homebuilt jib
Well, I just threw together the website for my jib.
http://www.prism.gatech.edu/~gtg754t/BuzzJib The jib works pretty well, but I have some things I want to change. It is 10.5 ft. long and I tested it to about 23lbs. Once I make the wire supports it will be able to hold more. I am going to be updating pretty frequently as there are a lot of small changes I want to make. As an aside, does this look professional enough for use on a set? I am trying to become a cameraman as a side job. Is there anything I could do to make it better besides powdercoating or anodizing it black? (prohibitively expensive) |
It looks good....a lick of paint and you'll be there.
One thing I will mention is that it looks like your using a theodolite tripod and i attemted the same thing and because of the light cast metal they use they are not that strong and not designed for that kind of weight. Luckily enough when it broke on me there was no camera on it. Andy. |
Do you think I should make my own jib stand like this guy:
http://www.homebuiltstabilizers.com/...rane/index.htm The reason I went with that tripod is that it looked like the EZFX jibpod. Maybe they make theirs out a stronger metal. |
I would definitely recommend something a bit stronger, the stand that guy made looks good something like that would be perfect. Getting rid of the theodolite tripod would Save you the pain of seeing your camera in two pieces after falling 10 feet =)
Andy. |
| All times are GMT -6. The time now is 02:30 AM. |
