-   Jibs / Cranes / Booms (https://www.dvinfo.net/forum/jibs-cranes-booms/)
-   -   Extra Long RCA adapters? (https://www.dvinfo.net/forum/jibs-cranes-booms/470965-extra-long-rca-adapters.html)
Dave Allen January 13th, 2010 06:18 PM
Where does one get an extra long adapter that goes from the video output on the camcorder to the 3 banana plugs, preferably male, not female, all as an extension wire-set from the videocam on the end of a crane to the remote monitor?
Edward Carlson January 13th, 2010 07:30 PM
I don't understand why you would want to go to banana plugs. Why not just stay RCA? Monoprice has a lot of triple RCA cables with male plugs at both ends. You can get couplers that can connect male to male. Video Cable - <b>RCA Composite</b>
Dave Allen January 14th, 2010 07:01 AM
Maybe my term is wrong, (it usually is, lol )I am told it is an RCA to RCA extension cable.
Denis Danatzko January 14th, 2010 07:30 AM
It's relatively easy to make your own,
and you can then have them to just the length you need.
I've seen some sites that have them in lengths from abut 3 ft to 50 ft.
Check almost any cable supplier on the web.
Edward Carlson January 14th, 2010 09:02 AM
You said banana plug, which is this: http://www.made-in-china.com/image/2...s-Set-Four.jpg
It's used for connecting speakers usually.
You want an RCA to RCA cable. You can get up to 50' RCA cables from monoprice.com for only $13.52. (see link in previous post.)
Dave Allen January 20th, 2010 09:29 PM
Ed, yes, I was tripping out on how inexpensive those were at the link you provided, thanks!
Neil Anderson September 23rd, 2011 10:52 AM
Re: Extra Long RCA adapters?
If you are like me, then you usually don't throw out old cables. I had a TON of unused RCA cords raning from 3ft to 5ft when I got a cheap monitor for my Kessler crane. A quick trip to Radio Shack and for about $4 I got a couple packs of RCA unions. It's basically just a double female and it's a quick easy solution for connecting my camera to my monitor, now I can see what my camera is pointed at.
Don Bloom September 23rd, 2011 11:41 AM
Visit your local Radio Shack, they should be able to set you up with whatever you need. I've got everything from 3 foot to 50 feet with connectors to patch cable together to make give me about 200 feet. Not that I would ever do that but I could if I had. Almost all came from RS.
