-   Jibs / Cranes / Booms (https://www.dvinfo.net/forum/jibs-cranes-booms/)
-   -   Any Jimmy Jib "lite" users? (https://www.dvinfo.net/forum/jibs-cranes-booms/26271-any-jimmy-jib-lite-users.html)
Steven Wills May 20th, 2004 07:47 AM
Are you considering purchasing a Jimmy Jib Lite? Are there any other users out here using the lite?
James Emory May 20th, 2004 10:08 AM
Jib Lite
Howdy Steven. Do you not remember posting on this thread just last week and then 3 times prior?
www.dvinfo.net/conf/showthread.php?threadid=3055
Mel Williams April 28th, 2005 07:29 PM
Jimmy Jib Lite
Hi Steve,
Yes, I'm thinking about purchasing a Jimmy Jib Lite (w/ cable).
Is this difficult to operate?
Mel
John Plunkett April 28th, 2005 07:59 PM
The company I work for recently purchased a jib from EZFX. It's really well built, easy to transport and a pleasure to use. It doesn't have the cable controlled pan/tilt option like the Jimmy Jib, but depending on the height you wish to reach, there are options.
Pricewise, compared to the 9' Triangle jib that Jimmy Jib offers, you can get the same length jib PLUS a Varizoom motorized pan & tilt head for much less. Granted if you are looking for a jib that goes beyond 9' then Jimmy Jib is your perfect. 40 feet! Man, that's high!
Ed Liew April 29th, 2005 09:37 AM
hi steven,
are you selling your jib?
ed
Mel Williams April 29th, 2005 09:51 AM
I was thinking about the Jimmy Jib Lite (with cables). It goes for $2,775 + 650 tripod + 755 6ft extension + 608 addn'l 6ft extension. I'm thinking about getting the main unit + tripod for the time being and then adding the extension arms when I get some more money. $2,775 + 650 is close to the Varizom MC100. Man...those Jimmy Jibs look solid.
Boy...wish I can get a used Jimmy Jib Lite :)
Tim Clark April 29th, 2005 10:30 AM
Hey, Mel
If you're thinking about a Jimmy Jib or EZFX, you should check out the MICRODOLLY Jib. Comparable price range, lighter, easy to use, and expandable. Not to mention we've got a system where you don't have to carry around all the gym weights -- you can use our folding weight cage to hold just about anything as counter weight.
Mel Williams April 29th, 2005 02:09 PM
pan and tilt
Hi Tim,
Can I pan with your jib? Or do I need to get the Varizoom MC100?
thanks,
Mel
Tim Clark April 29th, 2005 04:57 PM
Well, the Jib itself pans on the tripod. If you want to pan/tilt from the camera plate, we've also got our Power Head that mounts to our Jib (or anyone's Jib) and allows you to control movement through a weatherproof, cable-driven pan/tilt head.
