A Jib for the Wildlife Filmmaker
I've have always enjoyed those shots that are created using a Jib and would like to incorporate these shot types into my own work.
I shoot Natural History exclusively and everything takes place in the field! I am often filming in windy conditions but there are a few times when I get a reprieve and could use a small Jib. I am looking for a lightweight and compact system to use with my Sony EX-3. Being able to carry it on my own in addition to my camera bag and tripod would be extremely advantageous. I have two tripod set-ups that I could use with the Jib; • Manfrotto 542ART Road Runner Carbon Fibre Tripod with Mid-Leg Spreader teamed with a Manfrotto 526 Professional Fluid Head • Miller HD 925 Legs with 990 Mid-Leg Spreader teamed with a Miller Arrow 55HD Fluid Head therefore would really be looking at a simple arm. After a little searching I have come across the Glidecam Camcrane 200 Jib-Arm which looks about what I'm after. I'd love to hear if anyone has this Jib and there thoughts or any alternative suggestions. I will note that I'd like to keep the budget below a £1000 if possible. Many thanks in advance and happy shooting, Paul |
Hi Paul...........
First off, your link to the Glidecam crane isn't.
You might want to check these out as they're slightly more local. Jibs, Cranes and Booms Being the proud owner of their K12 unit I can vouch for it's beautifull engineering, tho' it's certainly not something you'd want to be hiking over hill and dale with. It's just about carryable on it's own, but with a tripod, weights, camera and the usual suspects as well, impossible for one person to carry. As for jib use in general, there are some issues with them all. First off is the problem of camera control. As the camera is stuck a long way away, your Lanc controller needs to be able to do everything required to do the necessary. It may seem too obvious to even mention but there can be some gotchas. My Canon ZR 1000 controller has a pretty significant issue with focusing with my A1 for example, and funnily enough, not something I discovered till I tried the jib workflow as opposed to tripod. Then there is the external screen, yet something else to carry, along with the wiring harness and battery system. A must, as you can't see what the camera sees without it. Then something you've already mentioned - wind! Anything above the mildest zephyr and that jib becomes a wild animal, especially with an HD cam way out on the end. Locking the pan brake won't save your bacon either. Even with mine atop a set of Manfrotto 528XB's (designed for the job, but still have to obey the laws of physics) the sail area of the camera X the length of the jib from pivot to cam = more movement than a bucket full of octopii. Oh, and the 528's are gut busters in their own right. tripods, heads, monopods, light stands, camera supports, lighting supports, professional tripod 528XB - PRO VIDEO KIT HEAD,TRIPOD Just a few things to think about. CS |
One of these Long Valley Equipment | products came up on BBList the other week. I'd never heard of it but it looks really interesting, ultra-compact.
If you want something with more lift, I use the Hague Multijib that'll go upto 4m and take full-size cameras (just!) index Steve |
Paul,
I've used a ProAm DVC200 for a couple of years now. Even if it's a lightweight construction you have to bring with you a mass amount of weights to stabilize. For the Canon XL-H1 I use approx 10 kg in counterweight. So it can be a bit cumbersome to hike to far away places where no vehicle is allowed! As Chris tells you it's a lot of items to bring with you. But I've managed to do some trips alone with all this equipment. But I had to do several turns to and from to bring in the equipment. Oh, for special effects shot, I don't think so much else can beat using a crane/jib. |
Thanks for the quick replies! Very interesting stuff!
The weight does appear to be an issue but I do like the idea of the Extension Bar and the Jib Bag from Long Valley that Steve mentioned! Long Valley Equipment. According to the website the Extension Bar can reduce the weight carried by up to 60% - a huge saving when carrying the gear alone! Also the Jig Bag looks great as no weights need to be carried at all if you know you'll be shooting at a location that has Sand, Gravel, Rocks, etc.. in the vicinity - no weight to carry at all. The ProAm DVC200 Camera Jib / Crane mentioned by Per Johan looks just up my street with a good price tag too. It just getting it shipped that bothers me! ProAm Cranes. Closer to home is the Hague Jibs and I really like the look of the Hague HDV Boom K8 with Tilt Control but only supports up to 4kgs and it weighs a total of 7kgs. The camera I'm using would be the Sony EX-3 which weighs in at about 3.6kgs. If I used this Jib would it be pushing things too far. The Hague Multi-Jib K12 will hold camera weights up to 14kgs but weights a staggering 18kgs alone! Tough decisions to be made! Any thoughts as to whether the Hague HDV Boom K8 with Tilt Control is under-gunned for use with the EX-3. As for the ProAm DVC200 Camera Jib / Crane I can't see a maximum camera weight or how heavy the overall Jib is? Thanks for your input! |
The Glidecam is excellent for the price, goes up to 10' and is as smooth as any other jib. I've owned a Trovato Tote Jib, which was great and cost about 5 times the Glidecam. I later got a Glidecam because I needed the greater reach for a shot. I used it with a DSR250 and it was perfect for that weight. I did one shot with the DSR500, which required about 50 pounds of counterweights. It worked but I felt I was pushing the limits with that much weight out at the 10' length. At the shorter length it would be OK.I used it on O'Connor 50 legs, with a Gitzo 1338 head for the camera.
Thanks Bill!
Here's the link to the Glidecam Camcrane 200 Jib-Arm that I referred to in my original post! I am seriously looking at the Hague HDV Boom K8 with Tilt Control but need to ascertain whether it is pushing it to the limits when using it with the EX-3. I've emailed Hague and asked the question so will post here when I know the answer. |
Paul, did you get a reply from Hague?
FYI I have just purchased the HDVK8 jib and I am very impressed so far. At its shorter length it handles my XH-A1 with no problems at all and it only needs about 1.5 kg to be added to it. I can set it up in under 10 mins and pack it up in 5 mins, it works with no problems on my Libec LS38 tripod. To use it at its longest length I would be happier with a heavier tripod as I need to add too much weight, however the shorter length is what i will use most of the time. It will still hold the xh-a1 with no problems at full length and looks solid, its just the tripod that is the weak link. The whole thing packs up into a tripod style bag that I can comfortably carry over my shoulder. I know there are sturdier jibs on the market but I like you needed somthing more portable and so far this has been a great buy. Just got to wait for the gales and rain to subside so I can get some practice with it. can't wait for the spring. cheers John |
I am not very experienced in either cranes or jibs, but was exposed to one during a shoot last spring (an EZ-JIB model, which was beautilfully made, heavy and expensive.) The Pro-Am is well constructed, lightweight and flimsier than the EZ, but in the 8 foot length with my Z-1 on the end, so far I think it will suit my purposes nicely. I have seen the beautiiful images Per Johan has gotten with his, and that encouraged me to give it a go. I find with my Z-1 I need about 16-21 lbs on the other end to achieve balance (depending on WA lens adapter etc). With the Sony WA adapter, and a tripod head on the end of the crane for the camera I use 21 lbs. With the camera and lens and tripod head (about 7 lbs) the crane itself (12 lbs) and the balancing weights (21 lbs) you are looking at 40 lbs on your tripod and more importantly tripod head. Plan accordingly. I am still trying to figure out the best way to mount it, tripod head or bearing mount without the tripod head, but am leaning on a non-tripod head mount. As noted above, I am also experimenting with a tripod head on the camera mount too.... that is looking promising... but adds weight to both ends of the equation (about 5 lbs overall I think.) Also, get the tilt lock if you purchase one. It is pretty essential if you use it in unlocked mode in my estimation. I am going back to get one. I also added the bearing to the camera end.. was it worth $24? I dunno...never got a chance to compare it to the other version. My complaint about bearings is that it would have been nice to put them all along the length of the pivots for the tilt rod... tilting while shooting is a difficult affair I find, and I think the lack of smooth bearings along that rod may contribute to that problem. All that said, for the price it is pretty hard to beat, and I am happy with mine. I have heard, and can better understand after using mine, that the 12 foot model may be pressing your luck stability wise unless you are intending to use it in a locked shoot position for vantage point. Also it takes some practice to get smooth starts and stops even with the 8 foot model, and I am sure the extra 4 feet magnifies every little mistake even more. I do think using a wide angle lens on the camera is the way to go on this, just my 2 cents, and why I mentioned the weight issues etc, since that glass is usually heavy. Hope all this helps. ps. for shipping, Bargain Camera says to plan on 30 lbs, because the box dimensions come into play and 30 lbs will give you a good estimation of actual shipment costs, at least domestically here in the US. |
Hi John,
Thanks for the reply and recommendation. Yes I finally got a reply back from Hague this week and they say that the Hague HDV Boom K8 with Tilt Control is more than doable as long as I don't exceed the 4kgs maximum weight. So in my case I'd probably not use any extras such as microphone, hard -drives and the larger batteries just to keep the weight down. More than likely I'll also remove the viewfinder to aid the weight reduction. I am looking at a package deal from them with external monitor, extension cables and so forth. It looks like a good deal and they are located reasonable close keeping the shipping costs down for me. I can relate to you about waiting for the gales and rain to subside!!! Hi Chris, Thanks for reply! Having looked at both the Hague HDV Boom K8 with Tilt and the Pro-AM 200 I feel that they have so many similarities it would be hard to pick between the two of them without trying them side by side. I'm opting for the Hague as they are the right side of the pond for me. Interesting assessment about the bearings. I have asked Hague about the tripods I have and what their thoughts were. The response was that the Manfrotto by design wouldn't really be up for the job and it can only hold a maximum of 15kgs. The Miller however is a much sturdier design with better leg locks thus will support the Jib adequately as it can support weights up to 25kgs. I think I'll be shooting wide as I'll help damper my inexperience of Jib work and will hopefully help my produces some usable shots in the earlier days. Quote:
Thanks for all your responses which has helped and guided me too getting the right Jib Very much appreciated! |
Glad you've taken the plunge. look forward to seeing your work.
cheers john |
It's ordered just waiting for it to arrive! I've not used anything like this so it'll probably take some practice to get usable footage from it. Will post my first efforts for advice and critique once I'm past the extremely embarrassing stage! Practice makes prefect as they say!
Good & economical crane / jib
I have a small jib built by glideshot. It limited in size but a great product. index
I have used it with a full sized HD camera (Panasonic HDX900) with good results. I would recommend checking out this product along with their other items. I also have two camera dollies they produce, both work really well. David www.lunaseafilms.com |
Hi David,
Thanks for the link! Interesting site! However I have already placed my order with Hague which as apparently has been shipped today so I should have by Tuesday next week (I live on an Island!)! I’ve tried a friend’s which has worked very well and I’m more than happy! I suppose the only thing for me now is to practice, practice, practice and practice! I’ll post some footage once I’ve gotten the hang of it! |
Well I've received my Jib and have assembled in my living room just to check it out (can't actually use it in there though!!!) as it's blowing a gale outside! Hopefully the wind will drop sometime this week so I can get out and try it!
First impressions though is - it's an awesome bit of kit! Thanks once again to all of you for your input and advice! Happy shooting, Paul |
Hi Paul, glad you are as pleased as I am with the jib.
I eventually managed to get outside with it for about an hour (in between the rain/wind) and I took it down to the harbour, its a steep learning curve and I need a monitor but it was easy to carry / setup and opens up a whole new dimension to filming. Now if only the weather would improve! |
Hi John,
Thanks! It is a pretty cool Jib Arm! I can relate to you about the weather - hopefully it'll improve soon! I purchased a monitor direct from Hague themselves for less than a hundred. I had to remove a swivelling cover in order to access the 1/4" socket and modify some cables but it's good for the money! Check them out here - I got the LCM 700 |
Hey David, could you tell me what the boom range is on the Glideshot jib(from the lowest it will go, to the highest)?
Glideshot
Hi Eric,
The arm is on the short side, I am away on a shoot so can not give you exact figures as it is at home but gives a rise/fall of about 4' to 5'. It is a little limited but I like the fact this is small enough to carry to remote locations etc. Height etc is obviously governed by what legs you mount this on. Michael at Glideshot is very helpful if you have questions David |
Thanks for the response David. With the arm only measuring 4 feet in length that's what I was estimating it would boom. The boom range would be plenty for this cave documentary I'm going to start on. I did some test shooting and cranked to the center column of my tripod down to see how it would look. It looks cool even with the 1.5 feet of travel I had, unfortunately its to slow and jerky. Looks like I will be ordering this jib. Thanks for the recommendation David.
Cave shoot
Hi Eric,
I may have misled you, or at least need to clarify, the arm is allows a travel of around 4' which is pretty good for a project like yours. The other thing I did was make an extension piece that puts the counter weights further out from the center of the arm, meaning you need less weight. That is good for when you need to transport the kit. David www.lunaseafilms.com |
Nah, you didn't mislead me. If anything my last comment was worded poorly. The Jib says it is 4 feet in length so I guessed it would give about 5 feet of boom travel. It looks like I'm a little off in my guess, but like you said, this should be more than enough for my project and I ordered it last night.
Thanks again for the clarification though. |
To give a little more info on this jib. It will boom 3.7 feet. It goes much higher than it does lower....although if I were to cut out a notch at the plate that attaches to the tripod it should be able to go lower.
The way everything is now: Tripod height 2 feet 10 inches. Jib's Baseplate for camera lowest height 2 feet 2 inches. Jib's Baseplate for camera at highest boom level 5 feet 10.5 inches. Total Jib boom height = 3 feet 8.5 inches if my math is correct. It's to early to make a judgment on this support yet(I've only played around with it for maybe 30 minutes, I still need to buy weights to balance it out. Next step should be some sort of pan/tilt control. |
