-   High Definition Video Editing Solutions (https://www.dvinfo.net/forum/high-definition-video-editing-solutions/)
-   -   24F... A Riddle for the Ages (https://www.dvinfo.net/forum/high-definition-video-editing-solutions/79035-24f-riddle-ages.html)
Matthew Nayman November 6th, 2006 07:48 PM
Okay... so, canon's 24F clearly looks great, but it cannot be exported back to tape and isn't supported by a lot of apps and by NO decks...
Here is a question... can 24F material, like DVX and XL2 24p, be nested into a 60i timeline without losing it's look? This would enable it to be dumped back to tape and to be accepted by more apps for post work.
Or, is it possible to convert 24F into true 24P HD? Also, will Magiuc bullet 2.1 do HDV 1080i 60i into 1080i 24P (makes no sense, I know)
Nate Weaver November 6th, 2006 10:15 PM
It's not a riddle for the ages.
It can be done, people do it all the time.
Matthew Nayman November 7th, 2006 12:50 PM
Care to explain how? I have missed it in all my research. I am working in Premiere Pro 2.0
When I try it, I get horrible artifacting and motion characteristics. Do I need to do it in magic bullet? If so, how?
Also, will those 24f/60i tapes then run in any 60i HDV deck?>
Matthew Nayman November 7th, 2006 06:20 PM
Nothing?
I am sure it is not too hard?
Nate Weaver November 7th, 2006 06:27 PM
I don't know how you yourself would do it, I'm an FCP guy. After Effects will do it, though. Decklink and Kona cards do it in real time so you can give people masters from 24p timelines. If you have a 24p timeline in DV, FCP does it real time in software so you can write to DV tape.
The proper term for what you're describing is "adding pulldown". Padding a 24p stream with duplicated fields so it adds up to 29.97. Do a search on that term and you'll prob find more info.
Matthew Nayman November 7th, 2006 07:42 PM
so in AE, how is best to go about it, seeing as we both know the program?
You take canon's 24F HDV files, start a composition with what frame rate? (60i, 24p?) and then do a pulldown (magic bullet? Proprietary), with 2:3 (what cadence? WWWSS?) and make it for a 23.976 timeline or a 29.97 timeline..?
Sorry ot ask so muc... trying to learn
