-   High Definition Video Editing Solutions (https://www.dvinfo.net/forum/high-definition-video-editing-solutions/)
-   -   Mixing DV & HDV in iMovie? (https://www.dvinfo.net/forum/high-definition-video-editing-solutions/78456-mixing-dv-hdv-imovie.html)
John Reilly October 29th, 2006 04:58 PM
Is there any way I can mix n' match both types of clips in a single project?
That is, some DV clips from an older camera, together in the same project with footage from my HC-1 shot in 1080i/HD mode in iMovie?
I'm suspecting I cannot, but was hoping someone had a cool work-around!
Thank You,
Reilly
David Andrews October 30th, 2006 03:57 AM
I am unfamiliar with iMovie - presumably you have already tried to do this. I think you either need a nle that can handle mixed formats on the timeline (such as Edius) or you transcode one of your formats to match the other. ProCoder or ProCoder Express should be able t do this for you. See here:
http://www.canopus.com/products/ProCoderSW/index.php
No doubt there are other converters around.
Bryan Kidd November 22nd, 2006 09:28 AM
Check this info from Apple...it might help
http://docs.info.apple.com/article.html?artnum=300830
