-   High Definition Video Editing Solutions (https://www.dvinfo.net/forum/high-definition-video-editing-solutions/)
-   -   Help Converting AVCHD (https://www.dvinfo.net/forum/high-definition-video-editing-solutions/78301-help-converting-avchd.html)
Luke Burgess October 26th, 2006 10:10 PM
Ok, I need to edit this stuff and i don't have the slightest idea how to convert these AVCHD files (windows says they are m2ts files once in the computer) from sonys HDR-SR1 into something that will work with Vegas 5. Any help will be greatly appreciated. Thank you
Luke
David Andrews October 27th, 2006 07:24 AM
I do not believe that any nles, that enable editing this codec, have yet been released. The list of supporters of the format can be found here:
http://www.avchd-info.org/
Sooner or, more likely, later some or all of these will deliver the goods.
Sean Seah October 27th, 2006 09:17 AM
looks like u r stuck now. Only way may be to convert it to DV from the cam. Have u tried with V6?
Jack Zhang October 27th, 2006 04:58 PM
You might want to wait until Vegas 7.0c or 7.0d.
Steve Nunez November 12th, 2006 01:07 PM
If they're m2t's, MpegStreamclip should be able to export to any NLE format.....this would be a Mac solution of course as I believe MpegStreamclip is a Mac-only program....not 100% sure.
Graham Hickling November 12th, 2006 06:19 PM
MPEGStreamclip works fine on PCs.
However .... AVCHD files aren't really m2t files, at least in the sense of m2t meaning 'mpeg2 transport stream'. They are mpeg4.
