-   High Definition Video Editing Solutions (https://www.dvinfo.net/forum/high-definition-video-editing-solutions/)
-   -   Exporting to H.264 in Premiere CS4 (https://www.dvinfo.net/forum/high-definition-video-editing-solutions/465721-exporting-h-264-premiere-cs4.html)
Ash Varma October 14th, 2009 07:17 AM
Hello All,
Hoping someone can help me with this.
I shot my Short on a Canon XH (HDV, widescreen, 23.97fps) and did all my editing in Premiere CS4 in HD. Everything looks great on the timeline and runs smoothly when I preview in Premiere.
I want to now export to H.264, so in the Options, that is what I choose.
In the section just below that I choose one of the High Quality, 23.97fps, 720p drop downs.
The complete film (~5 minutes) exports fine in about 20 minutes, but when i playback the footage, it's choppy and the sound is off.
Can anyone help?
Thank you.
Harm Millaard October 14th, 2009 08:03 AM
Usually this is caused by background processes running. Check with either CCleaner to prevent processes from starting at boot time or use Process Explorer to kill processes. I recently had similar issues on a notebook, that showed choppy behavior while playing a HD H.264 TS file and ending/killing several processes solved the issue.
Ash Varma October 14th, 2009 08:16 AM
Thanks Harm.
So you think this choppiness is just during playback? The actual file is fine?
Harm Millaard October 14th, 2009 08:53 AM
The same file when played on a Sony Vaio VGN-FW31ZJ was choppy and on the desktop flawless. Even when playing from a slow USB drive. It was only a matter of processes running in the background.
Ash Varma October 14th, 2009 09:19 AM
okay, i will double check.
thanks.
Ash Varma October 15th, 2009 01:57 PM
It worked!
It was apparently the Quicktime player i was using.
When played with Windows Media Player, it worked perfectly.
Cheers.
