Best server motherboard?
I may have some extra xeon 3.0gig 800Mhz fsb chips that I am looking for a dual motherboard to put into an XT chassis.
Any suggestions on a brand? Thanks Dave |
Get yourself an Iwill DK8N. Lots of RAID options with 2 different SATA controllers. PCI-X slots. Firewire. Gigabit Ethernet.
Thanks for the input, but since I already have the Xeon chips, can you recommend a MB that supports these.
Thanks Dave |
I'd suggest something from the following list, or maybe one of the latest Intel motherboards.
http://www.canopus.com/us/products/EDIUSNX_for_HDV/pa_EDIUSNX_Compat.asp |
Well if you must go Xeon then one of the SuperMicro X6D* series motherboards would be a good choice. Or a Tyan S2676 board.
Don't forget that these boards are larger than normal and will require a case for Extended ATX boards. And a power supply to match. |
Can anyone explain the differences between the Intel 7520 chipset and the 7525 chipset.
I'm in almost the same predicament DBK |
<<<Can anyone explain the differences between the Intel 7520 chipset and the 7525 chipset.>>>
For the full technical descriptions of Intel chipsets, see this link: http://www.intel.com/products/chipsets/index.htm |
