-   High Definition Video Editing Solutions (https://www.dvinfo.net/forum/high-definition-video-editing-solutions/)
-   -   Capturing SD recorded audio to HD edit (https://www.dvinfo.net/forum/high-definition-video-editing-solutions/235068-capturing-sd-recorded-audio-hd-edit.html)
John Whiteway May 10th, 2009 01:12 PM
I'm soon to upgrade my FCP to edit in HD. No manuals to check yet so my question is: can Final Cut Suite set up to edit a 24p HD project capture and use audio from SD recorded tapes?
Thanks.
Canada John
Battle Vaughan May 11th, 2009 08:42 AM
You can set up your FCP timelines with whatever audio and video perameters you want. Some SD (Betacam, for example) audio is 32k,12-bit whereas hd is normally 48k, at 16 bit.
So if your timeline is 48k, when you import a different sample rate, FCP will have to render the audio line to match the timeline. No biggie. / Battle Vaughan/miamiherald.com video team
