HD settings help...
I'm in PAL land running EDius Pro 3 with a Pentium 4, 3.2 GHz and 1 GB RAM. All been great with my old 4:3 Panny SD but now I've got a Canon HV20 and when I capture the PC won't keep up with the camera so more grunt obviously required.
What should my original settings be and after editing what export settings in Procoder express? The little bit of movie I've just captured took for ever to convert in PCE. Used to love the screenshots that Anton would do in the Canopus forum, is there anything similar? that forum seems to have been down for ages, how much longer? |
Forum is back up now. You will need to re register.
Ron Evans |
Ron I'm still getting "forum closed for maintenance , try again later. The letterhead has changed though, big yellow thing for Grass valley.
It just worked for me. You will have to re register your old bookmark will not work if that is what your using. Just go to the Canopus site, go to the forum tab and register.
Ron |
Try this link: http://ediusforum.grassvalley.com/forum/
