-   Grass Valley / Canopus NLE (https://www.dvinfo.net/forum/grass-valley-canopus-nle/)
-   -   Frame buffer ? (https://www.dvinfo.net/forum/grass-valley-canopus-nle/93463-frame-buffer.html)
Gary J. Walker May 7th, 2007 05:30 PM
Frame buffer ?
I have a great new system built by GuyGraphics in Utah, Question, I have my buffer set at the highest setting (96) works fine, but noticed that when either the audio mixer, or multi-cam are opened the buffer only ramps up to 5, out of 96 is that normal. (ps the only problem I have noticed is when your done video editing and want to add another audio track and want the mixer opened, even a simple 1 sec. disolve will need rendering)...Gary
John Richard May 8th, 2007 09:53 AM
This has to do with being able to ride the mixer to make level adjustments in real time as you are listening to your track. The mixer environment has to be close to real time for your input to accurately record your level changes.
Gary J. Walker May 8th, 2007 12:19 PM
Thanks neighbor, Can you check when multi cam, is activated my buffer hovers at about 4-5.. is that also normal Gary..
John Richard May 9th, 2007 08:38 AM
Sorry Gary, we're still at 3.62 and thus no multi-cam to test with for you.
The GV forums are back up and you may get an answer there.
Gary J. Walker May 9th, 2007 10:28 AM
didn't know that, I'll check, thanks for the help. Gary
Mike Downey May 12th, 2007 06:53 PM
Yes it is. When you are using multicam you are setting markers on the frames where you want to change the camera.
In the settings you will find that you can skip up to 5 frames while in multicam mode meaning that it only plays one out of five frames for each of the cameras.
This helps to keep playback smooth on HD.
Mike
