Recommendations for new Edius NX system
I'm thinking about making the move to HDV and will need to upgrade my computer. I will be using the Edius NX card. I currently use an off-the-shelf Gateway Pent D 820 2.8 Ghz machine to edit DV. For SD DV, this computer rocks. I'm looking to be able to do the same things I do now, only in HDV. Any ideas what type of system I should go for to be comparable to my current one, only to be able to edit HDV? A loaded question, I'm sure...
If a Core 2 Duo, should I look at an E6600 or 6700? Or would I be better off going with a dual core Xeon 5130? I'm concerned with performance but also want to keep the cost down as much as possible, as there's cameras to think about as well. Any input would be greatly appreciated. I do occasional p-in-p (though not that often), some slo-mo, and maybe a filter or two per clip (color correct, etc.). Nothing too outrageous. I shoot weddings so need to edit 2-3 cams for ceremonys. Thanks! |
Lee,
I was in your boat a while back while still in SD. I was using P4 3.4ghz HT. Upon migrating to HDV however, it wasn't enough. I am currently using a Core 2 duo and so far, for 720P work its stable and does the work, its value for money. Just make sure you have Lots of ram and a good graphics card with dedicated DDR2 ram of at least 256mb. Happy easter, Ted |
Ted,
Just wondering what Core 2 Duo you are using... 6400,6600,6700, 6800...? Also, do you have to do much rendering or is most of your work realtime? Thanks, Lee |
Lee,
im using 6600, real time in almost all situations even with nested sequences. Ted |
Anyone else...? Dual Xeon or dual core...???
For the future I would consider the Dual Xeon Dual or Quadcore Cpu's. They will not be fully utilized as of this moment but hopefully in the near future they will :) Mike |
Mike - do you know if 4.5 beta being shown at NAB was written to take advantage of the Quad Cores?
I could be completely wrong but I do not believe it does. 4.5 is more of a GrassValley integration and not a Major release.
The Ability for Edius to work seemlessly with other GrassValley products as well as working with the codecs needed. There are and will be bug fixes and the GUI has a whole new look but it still functions the same :) I will find out for sure though and lt you know. Mike |
Does this mean integration of j2k ( jpeg 2000 ) and support for the infinity line of products?. Can Edius 4.5 edit j2k in real time?. |
I will finding out today :) |
Yes. J2K is supported. It is a heavy format so editing in it is not easy but native support is in 4.5 |
Is the HP xw8400 certified for EDIUS NX Express?
| All times are GMT -6. The time now is 11:44 AM. |
