24F now supported by Canopus
See http://www.canopus.com/canopus/press/whatshot.php
"Canopus has released the v3.61 update for EDIUS Pro 3, which primarily adds support for the new JVC and Canon high definition video formats, including 1080p and 720p, with editing presets for the 24fps frame rate." The update is free; download it a trial version of Edius (for PC) from the link above. |
"This update is free to all owners of EDIUS Pro 3, EDIUS Broadcast, EDIUS DVX/DVStorm XA, EDIUS NX, and EDIUS SP."
Is the Edius DVX/ DV Storm, the same as the regular DV Storm? I have the original Storm card, and I'm thinking about the H1, but with that heavy price tag, I wouldn't be able to get much else. |
Hmm, if I were you, I'd consider setting aside about half of your budget for your editing system. HDV will require a newer, more powerful editing computer... unless you're okay with editing in standard definition for now with your current NLE.
That is the burr in my blanket, to put it in Texas-speak. My PC is actually fairly decent, but I have a hard time replacing something that still works. IF I were looking at shooting nothing but HD, yeah... I would likely need to replace a good portion of my hardware and software. But, if I end up mostly shooting SD, I can continue on my merry way as is. In theory anyways.
As it is, I usually end up shooting second cam for someone, and haven't edited anything for a client in ages. I would be more inclined to put money into some lights and batteries, where I really need it, and leave the PC as is. |
No....the DVStorm does not support HD. The Canopus forums have more info on what you would need. |
That answered my question then. Thanks Wade.
No problem. I wish it did to somehow..lol..I heart my storm.
Storm will not support output to monitor of 1080/720...for that you need an Nx or Sp card. But Edius ohci will get the job done for all the HDV modes of the H1. Now if you have a Storm you can use the HDV footage in a Sd project setting and you will get Sd output to monitor out of Storm. Also Edius is due for a big upgrade with 4.0 which will be showing at NAB.
Well... It might be time to update the Storm, if I ever start doing HD.
In addition to what Randy said, you can also use Edius to edit HDV footage with an SD project setting and then use the DVStorm MPEG2 encoder to output a widescreen DVD file in real time -- something no one else can do right now without a tremendous amount of processing power. This is my preferred output solution for my HDV projects at the moment, and I'm pleased to see my DVStorm continuing to be useful. DON'T DITCH YOUR DVSTORM CARD!!!
Richard |
Richard is right...Do not count on using a Storm or for that matter any of the new cards with anything other than Edius.
Man... Y'all are killin me! Fine- I'll get the XL2 then! Sheesh! I really didn't want to delve into HD, maybe play with it a little, but certainly not do it as a mainstream thing. I like the Canopus card itself, but was never overly fond of the program. What is the situation with Avid and all these funky new formats?
| All times are GMT -6. The time now is 11:43 PM. |
