It's Coming Thurs - Any recommended project settings for 60i/24F - EDIUS etc?
Hi all - mine is coming Thursday, and I've just started to experiment with the workflow. I think the wildcard is going to be the 24F settings, especially if I want to combine it with 60i material. Perhaps this is a no no overall, but I can see wanting to use nice 'filmic' 24F clips, and then going to 'hyper-real' 60i clips as well. Wouldn't mind knowing various opinions/options on format combinations.
I currently have Edius 3.6+ which touts the necessary presets for the Canon camera. The 24F clips look nice in a 1440x1080 24p setting - a bit strobey on motion, but I figured that was an issue of pull-down, no-pull-down, my general ignorance of the two - plus any 24F stipulations, my monitor, or maybe it's all good. Putting a 1080 60i clip works on that timeline as well, but you lose the 60i hyper feel (expected of course on a 24 progressive timeline - which still gives a nice 'filmic' look). A 1440x1080 30p setting may be just between on 24F & 60i clips. A 1440x1080 60i project looks incredible on the 60i, and pretty good on the 24F as I recall. It may lend to some trailing/ghosting/strobing - I can't recall. A nice thing about Edius is that it will play just about any kind of clip you stick in there (including 25 frame PAL stuff). Unfortunately for my current workflow study - I kind of wish it wouldn't. Some lend to strobing, so I need to finalize my understanding of making clips conform/scale, etc. So - I'll be looking to experiment some more A final wildcard is that I also have the HD100, by which I may want to stick some 1280 24p/30p clips in there. That would really throw a wrench into it. I'm just wondering if I should pre-conform any 24P/24F material, scale other clips, or expect that I can just drop these various formats in on a recommended project setting timeline and just go for it. A lot of new environments to play with these days - thought someone might have a general workflow suggestion. I'm sure the best suggestion is to stay with one format for the project, and go with that... I expect I'll be shooting a lot of events as 1080 60i, so I'm set for that. It's the frame size/rate add-ons that might keep me honest. Sorry for the babble/length, and thanks, Shawn |
BTW, I guess this is all contingent on how the 24F test footage around here was shot (2:3 or 2:3:3:2). Pulldown is fairly new turf for me, so I'm continuing to experiment with what's available until I have camera in hand, making assumptions along the way.
Had some fun tests tonight with the encoding side as well - made a goof and was initially encoding lower field first - I assume I should be encoding upper field to coincide with the source material (?). Played with the encoded frame rates too in ProCoder 23.976 & 29.97. Some results seemed great. Lots of combinations - I'm guessing its a 24pA to 29.97 timeline combo to get what I want, but perhaps I need to re-render some footage prior to that, etc. Any words of wisdom are appreciated. It's getting close anyway... Thanks, Shawn |
*edit*-- I guess there is NO pulldown in 24F mode to tape. It's a true 24p recording to tape, but the playback through the camera adds the pulldown, even through firewire. Quote:
The strobiness you may be complaining of when viewing the m2t's is probably the pulldown of the 24F that looks like it hiccups a little bit on a progressive computer screen. The m2t's I captured were from HDVxDV and they are 29.97 clips of 24F material. If you're talking about the strobiness *in general* of 24p, well, as you probably know, that's just the nature of the beast. Your 24F material, combined with 60i, will look normal on a 1080i display, particularly when rendered back out with the correct pulldown. |
| All times are GMT -6. The time now is 01:19 AM. |
