-   Grass Valley / Canopus NLE (https://www.dvinfo.net/forum/grass-valley-canopus-nle/)
-   -   Help: Migrating Edius 5 with (NX Bay) to new OS (https://www.dvinfo.net/forum/grass-valley-canopus-nle/527372-help-migrating-edius-5-nx-bay-new-os.html)
Claudia Eklof March 21st, 2015 06:31 AM
I am looking for a discussion on "Considerations when migrating Edius5 (with NX Bay) from Vista to Win-7 Professsional."
Background:
I archive old footage (standard definition media) using old tech. Edius 5 with NX Bay (RCA and S-Video connections) plays a key role.
The pain comes from dealing with the Vista OS. I've decided it is time to tweak my process and dump Vista, if at all possible.
Yesterday, I checked with Grass Valley before attempting to migrate my OS system and I was informed that End of Service for Edius5 was back in 2012. They cannot advise me, but there is always the Forum.
Some initial questions:
--As Edius5 is no longer supported by Grass Valley, How best to secure a smooth migration from Vista to a clean, new version of Win7 Professional? (Drivers and such.)
--Would a newer version of Edius (Edius 6, or newer) still utilize the functionality of the NX Bay? I would be willing to upgrade the software, if I could still have the functionality of the NX Bay.
Jim Andrada March 21st, 2015 10:47 PM
Re: Help: Migrating Edius 5 with (NX Bay) to new OS
I'm pretty sure I was running it on Win 7 just fine - but at the moment I have Edius 6 installed so this is just my all too failable memory.
Claudia Eklof March 22nd, 2015 11:37 PM
Hi Jim. Thank you for your reply.
Just so I'm clear: You are able to access your NX Bay utilizing Edius 6? If so, upgrading to Edius 6 would be something for me to shoot for. Please confirm.
Alternatively, another Forum member suggested (offline) swapping out my C:/drive for a new HD and doing a clean load of Windows 7 onto it. If something were to go awry with Edius 5 running on Windows 7, I could swap back the original HD and, well, no harm done.
It's great to have these suggestions. I'm feeling much more positive about a good outcome.
Thanks to you!
Don Palomaki March 25th, 2015 09:37 AM
The NX card is supported by Edius 7 Pro as legacy hardware..
The Edius forum/board is at Grass Valley Forums
It is both active and helpful.
Edius 7 Pro is a 64-bit app so you will need 64-bit Win 7
It no longer uses the dongle.
Projects saved from Edius 7 are not backward compatible with Edius 5.
Your version 5 plug-in pack is not available in Edius 7, you may need to upgrade them if still needed.
Claudia Eklof March 25th, 2015 09:50 PM
Hi Tim. Thank You. Many good points.
Indeed, I checked with Grass Valley support, but didn't check with the GV Forum.
Interesting about the lack of backward compatibility in Edius 7 to Edius 5. May need to run both versions for the foreseeable future.
Claudia Eklof March 27th, 2015 08:54 PM
No, no, no! So very sorry: I meant, of course, to address Don P.
Don Palomaki April 3rd, 2015 05:30 AM
Call me anything but late for dinner!
It is not appropriate to install/run different versions of Edius on the same computer. Folks who need to run multiple versions usually do it by having separate boot drives for each version of Edius (or a dual boot configured PC).
Edius 7 should be able to open Edius 5 projects, subject to having available any applied filters, effects, and transitions.
Claudia Eklof April 4th, 2015 02:27 AM
Hi Don,
Yes, I'm with you on the separate boot drives. The PC in question has a total of 5 hard drives (two of them boot drives). Seemed wiser to keep the old system at hand should anything go wrong with the OS upgrade. Contingency planning.
So far, Windows7 Pro is working like a dream in general and Edius 5 in particular is loving the updated OS. Edius 7 will come in handy down the line, and I'll run the two Edius versions, as you clarified, on separate drives until I'm satisfied Edius 7 can deliver without loss of continuity from Edius 5. I'm being cautious; surprises are not good for business.
Thanks for checking back with me.
