-   Grass Valley / Canopus NLE (https://www.dvinfo.net/forum/grass-valley-canopus-nle/)
-   -   Edius boot key? (https://www.dvinfo.net/forum/grass-valley-canopus-nle/480370-edius-boot-key.html)
Dale Guthormsen June 14th, 2010 09:20 AM
Edius boot key?
Every once in a while when I start up my computer with the key left in the usb port I get a window stating there is an unautorized windows access. Never has happened prior to edius and using the key.
Should I be pulling the key out at every shut down???
I am using a 64 bit vista I7 Dell workstation
Any ideas?.
thank you,
Richard Hunter June 15th, 2010 02:47 AM
Hi Dale. I always leave the Edius dongle plugged in, and have never had this problem with Windows XP Pro or Windows 7 64 bit.
Richard
Anton Strauss June 15th, 2010 05:51 AM
sounds like you have windows defender enabled, stop it and set startup type to disabled
most useless invention ever by Microsoft
Dale Guthormsen June 17th, 2010 05:10 PM
Good afternoon,
I actually have defender off.
Any other ideas??
dale
Anton Strauss June 17th, 2010 10:31 PM
install the latest dongle driver from the aladdin website HASP Drivers - USB Device Driver Downloads
also, some more tips here
Win7 64bit Performance Improvement Tips for Edius users
Dale Guthormsen June 20th, 2010 08:24 PM
Good evening,
thanks, I give those a look over!!
Pat Sipes July 15th, 2010 09:43 PM
Good advice from Anton. You should leave the dongle in unless you need to take it out to go to a different machine.
