-   Grass Valley / Canopus NLE (https://www.dvinfo.net/forum/grass-valley-canopus-nle/)
-   -   24p DVDs from Canopus (https://www.dvinfo.net/forum/grass-valley-canopus-nle/23548-24p-dvds-canopus.html)
Peter Moore March 26th, 2004 07:27 AM
Does anyone know if it's possible to make 24p DVD-compliant MPEG-2's from Canopus Procoder? I can't seem to get Maestro to like the file. It does like the Vegas Main Concept 24p output. I want to give it a 24p DV file made from Vegas and get a 24p dvd-compliant MPEG2. Thanks!
Peter Moore April 5th, 2004 03:49 PM
So does anyone know? Am I missing something? Thanks.
Peter Jefferson April 6th, 2004 02:13 AM
you might be able to set the frame rate, however i dont know what the drop down set up woudl be, im in pal land so i dont have to worry bout drop downs, but in teh end, i find that the Mian Concept encoders are quite clean.
Procoder is good, but slow...
I can do a full hours worth of avi into mpg2 at about 2/3 realtime using main concept.
if i use procoder, it would take a lil under 2 hours...
Edward Troxel April 6th, 2004 07:22 AM
Out of curiosity: If it accepts the Vegas 24p output, why worry with ProCoder?
Peter Moore April 6th, 2004 08:51 AM
Cause I like pro-coder's mastering mode, 2-pass VBR much better than the MainConcept encoder.
Edward Troxel April 6th, 2004 09:20 AM
OK. I can see wanting 2 pass over Vegas' single pass VBR.
Peter Moore April 6th, 2004 10:09 AM
Yeah, this is for mastering. These DVDs will probably be replicated DVD-9s, high bitrate, etc. So MainConcept's not going to cut it. :)
It's filmed on Panasonic DVX100A's, so I really want to take advantage of 24p DVD players and HDTVs. I could telecine it with little trouble, but that almost defeats the purpose.
