Changing file types for .m2t's
Hello All,
I have been lurking around for a long time, thanks for all the info to all those who contribute. I have a bunch of .M2T files that I am trying to rename to .mpg's; yes sound simple enough. But I inadvertently assigned Windows Media Player as the program to open the .M2T files. Before I could windows would give me that unknown folder icon for the .m2t files, and I could just erase .m2t and replace with .mpg and viola all my windows app treated my footage as .mpg's. However now, with WMP as my file assigned file opener I can't change the file type by changing the file extension name. There has to be a simple way of unassigning .m2t's so I can rename them. Any ideas? Chris |
To turn off this so-called "feature," in your file manager go under tools->folder options, the "view" tab, and uncheck "Hide extensions for known file types."
At least, this is the procedure under Windows 2000. Your mileage may vary with one of the newer versions. |
Just changing the extension does NOT change the file from "transport stream" to "program stream". VLC does this easily and quickly as it does not NEED re-encoding. The MPG file is just a little smaller as the transport stream has a little better error correction.
I think a program called MPEG Streamline can do it.
You Guys Rock Thanks Alot!!
David thanks of the extra info on the Transport/Program Stream I didn't realize that and I will look into it further. Chris |
For digging into .m2t, or into .ts files, may be you want to check PVAstrumento http://www.offeryn.de/dv.htm
Very informative... |
| All times are GMT -6. The time now is 02:57 PM. |
