what pair to get
Hello everyone, i have a question that has been bugging me for a while. I plan on buying 2 HDV cameras, any brand, (i'm opting for a z1 and xlh1). The reason i'm not buying both of the same model, (2 xlh1s) is because of the lowlight possibility on a lot of the shooting areas. I know for a fact that the xlh1 shoots in 1080i at a res of 1920, but the z1 shoots at 1080i 1440 res.. Is it goingt o be difficult mixing and matching the cameras in post production with various resolutions, or is it not going to matter? Would it be better to just get two XlH1s in the long run? Any ideas? I'm new to the HDV workflow, i have an idea of how to accomodate post prod, but i'm wondering which pair of cameras I should opt for.Thanks
If possible, always get two cameras with a matching "look". It'll make your life much easier in post-production.
i completely understand that, i've dealt with dv cameras mostly when it comes to matching the output. What i'm worried about in HDV, is, if we get a Z1 and a XLH1, in 1080i mode, wouldn't both cameras still have diff resolutions? Also, any xlh1 users, how is the lowlight capability? does it rival the z1?
Edit: Canon's literature on the camera specifies the standard 1440x1080 resolution to tape, so your information is likely wrong: http://consumer.usa.canon.com/ir/con...2152&pageno=16 |
yeah, i checked up on that, and looks like I was wrong. Thats good though, that means I dont' have to worry about mixing and matching pairs, except for the color/gamma detail. Now my question is: which HDV camera performs the best under low-light scenarios?
For what its worth:
Rating from Canon: 60i, 1/60 shutter speed = 7 lux; 30F, 1/30 shutter speed = 4 lux; 24F, 1/48 shutter speed = 6 lux Rating from Sony: 3 lux @ 18db, F1.6, normal shutter |
Even if cost hadn't been a factor, I think I would still have chosen the FX1/Z1 over the H1, for the low light capability.
well I haven't bought the cameras yet, i'm still debating. I'm thinking the perfect scenario would be a z1 and a h1..
From the HDV/P2 shoot-out, I thought that the Canon was the clear low light winner? And yes they both capture 1440 to tape (Canon does full 1980 from SDI) but the Canon holds far more detail then the Sony.
Just going off the HDV/P2 shoot-out Douglas. Sony was lowest detail of the bunch. Canon was the highest. Both at 1080i. JVC at 720p was second. As a note the tests were done with artificial detail settings turned to "off", and in doing so the Sony went extreemly soft.
I'm not sure which camera is actually the better performer in low light. I've read conflicting accounts, so it is unclear to me which camera handles low light best (FX1/Z1 or H1), but from what I understand, the FX1/Z1 does pretty well, especially at holding down noise when gain is boosted (sounded like the safe choice in that regard).
Robert -"but from what I understand, the FX1/Z1 does pretty well, especially at holding down noise when gain is boosted (sounded like the safe choice in that regard)."
Your quite right Robert. The Sony holds up very well in that regard. In that same (and only comparative) test I'm aware of, it clearly showed that the Canon held a large advantage in the low light catagory. I would be very interested in hearing of any referance to the contrary, if you have one. |
I'm pretty sure I've seen at least a couple posts here that allude to better low light performance from the FX1/Z1, but I'm not sure where I saw them. I'll keep my eyes open and if I see one again, I'll try to point it out for you. I haven't seeing anything akin to "I put them side by side and one clearly blows the other out of the water" or anything like that.
thanks for the info guys, right now the z1 is only a candidate because of its possible superior low light, thats the only reason i'm opting for a z1 and h1 rather than simply 2 xlh1s..
| All times are GMT -6. The time now is 07:19 PM. |
